Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Zbrush_Displacement
  1. #16
    morph target
    Is there a way to export back to lightwave if you forgot to store a morph target? Can you recreate it some how?
    Wayne
  2. #17
    nowhere
    241
    Yes indeed .On Zbrush Tools menu ---> geometry go to the lowest level and press "cage" botton , it recalculates the basemesh for that displacement . then export .If you look with calm after press this steps rise the levels of displacement and return to the lowest, you can see the diference.
    Good luck
  3. #18
    TD/Animator lino.grandi's Avatar
    Jun 2003
    Rome
    1,700
    Quote Originally Posted by Wayne Heim View Post
    Wayne
    My advice is to NEVER use the morph target after the sculpting is done.
    You should just export the base mesh from ZBrush as it is after the sculpting.
    So....no need at all to save and recover a morph target.
