Results 1 to 2 of 2
Thread: Jazz Cat Whackiness
    Registered Gun Monkey @NiM8R's Avatar
    Feb 2008
    MS
    55
    Jazz Cat Whackiness
    Hello LW Masters!
    This concerns LW on my machine at work. There is a bit of oddness going on with a file provided with v9.3 that before today was operating normally. It came from the "Add content" folder under "motion mixers" - the object, scene and cat_motions files named "straycat.lws". As you can see by the attached screen grabs, it appears as though the wrong sections of some of the geometry are being controlled by another object or null. I have re-loaded the entire "add content" folder from the DVD which resulted in no change. I have the same set up on my machine at home and the "straycat" file is as it should be. I have tried everyhing I can think of to solve this mystery, so I now turn to the LW geniuses of the world for help. I will greatly appreciate any ideas -
    You noticed that too, eh?
    I have 3 separate versions of LW on my machine and each has the same issue.
    Curious!!
    Anybody shed some light here?
