Thread: Simple Skin render artifacts
    Orlando
    119
    Hey, I've searched around but am having trouble finding the answer to my problem
    Attached is an image of the problem im having. It seems like certain polys are going crazy with the sss.
    Thanks for the look-
    I don't think there's a 'fix' for that per se, it's a drawback of that shader; your different layers need to be more similar in color - well that's what I concluded just before I stopped using it...
    Confirmed -
    i just ran into this a few minutes ago. i think its the epidermal/subdermal distance. for mine i think the subdermal distance was set at 500mm when the epidermal distance was set to .5mm so it popped through. if that fixes your problem you could probably paint a black and white map to control it.
    "Remember, wherever you go, there you are!"
    Check out my website and demo reel.
    Thanks for the link erikals, I think that thread will be very helpful.
