Results 1 to 12 of 12
Thread: non-additive light?
    non-additive light?
    is there any way to make a non-additive light?
    or maybe there is a plugin?
    i'm trying to achive the effect to the right of this picture...
    Stuttgart, Germany
    13,585
    The lighting itself is computed within the shading, so you'd need a special shader as opposed to a special light.
    Basically, instead of adding all lighting, only use the maximum.
    Do you need it for a whole scene or just for a single surface with a specific set of lights?
    Cheers,
    Mike
    true, it more about the shading i guess, would've been nice to just add a light though.
    simple...
    i didn't quite understand... "Basically, instead of adding all lighting, only use the maximum."
    usually for this i only need 1 surface that is affected.
    i'm trying to use this for a non-GI sss trick i will post in the "Radiosity, animated" thread
    http://www.newtek.com/forums/showthr...=98861&page=28
    getting closer, but not quite there just yet...
    Stuttgart, Germany
    13,585
    simple...
    The former is what the shaders do internally, the later is how you'd like to see them behave.
    Using how many lights?
    Cheers,
    Mike
    ...3 lights should do i think,
    Stuttgart, Germany
    13,585
    In that case... use three single light illumination nodes from the db&w tools, one per light, run the results through a colour to scalar, then max them together and use the result to modify your plain surface colour.
    I just checked, unfortunately there is no max node for vectors or colours
    Cheers,
    Mike
    LightWave Engineer Jarno's Avatar
    New Zealand
    597
    Or fake it with a single spotlight with a mask in front of it?
    ---JvdL---
    Quote Originally Posted by Jarno View Post
    ---JvdL---
    nah, the problem is GI is too slow using SSS (unless it's Sigma2)
    http://www.newtek.com/forums/attachm...4&d=1254816678
    so i simply exclude the GI from the SSS sphere...
    however that creates zero light in the shadow, looking unreal
    so now, i add a second light, good, but it also adds light while it's in the light, making it look funny...
    hm, think i have an idea, adding a 3rd light... and excluding objects...
    nope, can't this to work.
    there might be a way using nodes, maybe Gerardo would know...
    it would probably have to be some sort of buffer node... or difference node, if such exists...
    hmm,...
    http://www.newtek.com/forums/showthread.php?t=71751
    http://imagic.ddgenvivo.tv/forums/PFconfig.png
    Super Member gordonrobb's Avatar
    Oct 2003
    Scotland
    1,323
    Or render each seperately, then comp them in Photoshop with a layer blending type that does what you want.
    ...yes, i kinda thought about it, but no blending type works... (tested all)
    ...but even if i did, it would in this case, as i'm rendering sss, make previewing the sss very tricky, going back and forth between PS - LW to see the effect.
    so, a good idea, but i'm finding it tricky at the moment.
    Dance Commander WCameron's Avatar
    Wilmington MA
    546
    I think the old Lume somethingorother from Dynamic Realities did this sort of thing. maybe G2 can?
    - Will.
    "All those with Psychokinesis, raise my hand."
    - The Doctor.
    The Room With No Doors
    by Kate Orman.
