Thread: Point Cache work with particles?
    Does anyone know a way to get particles to work with the verts on a point cache mesh? The particles don't seem to work or do anything if I choose the model that has the point cache added to it.
    Also is it possible to make particles work with a vertex map? I don't see any Vmap drop down in the particle tab? Verts/Posys/etc, but no Vmap?
    Thanks for any help.
    Hastings, New Zealand
    7,731
    Hit tge calculate button for emitting particles from deforming objects.
    Try using Dponts node texture procedural.
    Thanks SlineGod, I will give that a go. For the Dpoint, that will work with particles?
    7,731
    That node gives parts of LW access to nodal that normally wouldnt have it.
    You can also effect where particles are born using texture maps.
