Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: Grass with HDI/explanation + files
  1. #31
    just remember, it will never smooth the outer edges of objects, only AA can do that,
    so you definitely need some amount of AA...
  2. #32
    areté adk's Avatar
    Melbourne
    1,495
    yeah I'm sure they have their limitations (NeatVideo seems to introduce very slight artefacts in some cases) so I plan to do a lot more testing as to when these would be big time savers in the sorts of things I plan to use them in. It's the dreaded foliage pixel fizz, that no amount of time reasonable AA / AS / OS settings (rendering at x4 seems out of the question for now) that I'm looking to battle with. So far tho results seem extremely promising
  3. #33
    very true, http://www.revisionfx.com/products/rsmb is one of my favorites
  4. #34
    Malmö, SWEDEN
    7,624
    HD Instance just got onto my "things to buy" list!
    Senior Technical Supervisor
    Cinematics Department
    Massive - A Ubisoft Studio
    Intel Core i7-4790K @ 4GHz
    16GB Ram
    GeForce GTX 1080 8GB
    Windows 10 Pro x64
  5. #35
    Sinner Saved by Grace Larry_g1s's Avatar
    Dec 2006
    Bakersfield, CA
    2,454
    Got 404'd
    Larry Vasquez | Genesis One Studios | company showreel
    Someday, I will be a CG animator (student at iAnimate.net).
  6. #36
    Profesor Pixel Poo Mr Rid's Avatar
    Oct 2005
    Los Angeles
    2,792
    There are some post cheats that dont replace proper AA and moblur. But a sobel filter can make a quick luminosity mask that allows isolation of edges to apply post-blurring. This examples is zoomed 300%
    This moblur cheat only works on the outside of an object with an alpha, but it recently saved me a huge amount of render time for several elements that were moving rapidly thru frame and I needed to render out fast.
    I rendered a quick 12-pass version. Then it was easy to make a mask in comp that excluded the white and black parts of the alpha, allowing me to post-blur only the steppy moblur area. This took about 4 seconds per frame in comp as opposed to several more minutes per frame in 3D. The bronze colored part is the CG object, comped over a BG plate-
    "O K, so what's the speed of dark?"
    Demo reel 2017
    https://www.youtube.com/watch?v=yOOixvRhcs4
  7. #37
    areté adk's Avatar
    Melbourne
    1,495
    Quote Originally Posted by Mr Rid View Post
    I rendered a quick 12-pass version. Then it was easy to make a mask that excluded the white and black parts of the alpha, allowing me to post-blur only the steppy moblur area. This took about 4 seconds per frame in comp as opposed to several more minutes per frame in 3D. The bronze colored part is the CG object, comped over a BG plate-
    Nice work Mr Rid & thanks for another great tip ... now off to play with this in Fusion
  8. #38
    There are some post cheats that dont replace proper AA and moblur. But a sobel filter can make a quick luminosity mask that allows isolation of edges to apply post-blurring....
    interestingly, you could combine it with this technique...
    http://www.newtek.com/forums/showpos...&postcount=327
