Thread: Render Lines or Edges
    Nov 2005
    Houston TX
    26
    Can someone direct me? I have parachute with lines or edges for rope. How do I get LW to render the lines, is that possible? I searched the forum, some say plugin, some say can't do?
    ftp://ftp.newtek.com/multimedia/movies/w3dw/Hoop.mov
    2Point Polys show up in render. Check if you have everything is ok with your mode and surface.
    Good Luck
    Nov 2005
    Houston TX
    26
    Thanks, I'll check settings.
    Sep 2005
    Earth
    3,121
    keep in mind: Fprime won't render lines....
    Nov 2005
    Houston TX
    26
    Thanks!
    Thanks for the help, got everything working...
    LightJustice Panikos's Avatar
    Nicosia Cyprus
    1,727
    You can extrude them a little and get a thin line
    Super Member OlaHaldor's Avatar
    May 2008
    Norway
    986
    If you have LWCAD, use curves, and give them geometry with Profiler.
    3D Generalist
    Threadripper 2920x, 128GB, RTX 2080 Ti, Windows 10
