Results 1 to 12 of 12
Thread: Creating tenticles / Pipe...
    Newbie Member plankton's Avatar
    Mar 2008
    australia
    47
    Hey Guys, just wondering whats the best way to go about creating a tenticle or pipe? is there a way to get a cylinder to follow the path of a spline? if so? how do i go about doing this..
    cheers....
    Back from Monkey Island Weetos's Avatar
    May 2003
    France
    943
    Rail Extrude is what you may need :
    http://www.meshweaver.com/frames/tut...ailextrude.htm
    imho this is the best method, but you may also want to give Magic Bevel a try which allows to draw the tentacles/pipes with the mouse
    Hope that helps
    Mar 2008
    australia
    47
    thanks, that link was good, can use the rail extrude now, but is there a way so that it tapers to get a thick to thin pipe? or do i need to use another tool?
    May 2003
    France
    943
    In this case, use MagicBevel in spline mode (open the numeric panel 'n' so you can see all the options)
    This tool requires a little practicing, but once you get how it works, it's really efficient
    Mar 2008
    australia
    47
    cheers,
    thanks heaps for that.....
    Hastings, New Zealand
    7,731
    You can use rail extrude, extrude, etc to create the tentacle, To taper it use the taper tool.
    Mar 2004
    Northern New York
    5,254
    The rail extrude tool can use additional rails to determine the taper as well.
    May 2003
    France
    943
    Hey Silk, thank you for this information, I didn't know that ! I just tried and works like a charm - With multiple splines in the background layer, RailExtrude enters in 'Multiple' mode, which activates the tapering
    Learning new tips everyday !
    Mar 2004
    Northern New York
    5,254
    Your welcome...
    Aug 2005
    Chesapeake, Va.
    82
    I like using Bezier Bridge. It's free, works great, and is interactive. You can click in the window to add beziers. You can combine shapes. Start with a flat square and extrude to a circle. I love it. There are a lot of very useful plugins at artssphere.com.
    Bezier Bridge
    http://www.artssphere.com/plugins/bezierbridge.php
    Hope this helps.
    Cyatic
    thanks cyatic. The extude+ is a bit flaky (never got to finishing it), but it also can do tapering and a few other things that actually may be useful for tentacles.
