Results 1 to 15 of 15
Thread: Extender
    Extender tested
    Quick extender test
    watch it
    christian
    fL's handle subpatches selction in random order ..even try to trca edges, work in subpatch mode
    heya Drewitz!!!! very good demo.. i'd say FI's extender works great!!
    cheers
    Sweden
    48
    So, where can I find this amazing L-script?
    Johan
    Sweden
    48
    Lightwave Pimp Skonk's Avatar
    Yorkshire UK
    1,450
    Sweet
    uh wha?
    Great!!
    Thanks alot
    "Reality is just an imagination, Imagination is the true reality."
    [url=http://users.pandora.be/joril/][COLOR=firebrick][size=2][B].: visit my online portfolio :.[/B][/size][/COLOR][/url]
    You forgot to mention Fl's Extender's brilliant symmetry abilities too! This plugin is the best!
    You forgot to mention Fl's extender's symmetry abilities! They rock! I love this script!
    Newbie Member DaBo's Avatar
    Thuringia - Germany
    25
    Hmmm, I use the Poz Extender, works very good.
    If I need a bigger point selection I use the PlaneBelt_Selector.
    And sometimes, if I have 2 vertices and need a new polygone. All I need to do is using LW's Extender...and Voila ,I've a New polygone
    Sure, I've the other extender. But Poz Extender is the best for me.
    okay...Cya.
    well poz belt it stuf from the old dark ages
    band saw or pro doing the selction stuff now in lw !
    poz has the limitation to select points in order this sucks
    Thuringia - Germany
    25
    Sorry, but BandSaw can't select vertices (it select only new made verticeS)
    I mean PlaneBelt-Selector select a Vertices/Point Row...For example if U have a long long poly line (in a big size object), selecting the points with the laso take to much time...
    just mark two points use the pb-selecter and he select the row, finish
    I like that...
    Cya.
    Tip:
    I have quick key Home linked to Extender, Insert linked to Weld, and that way Extender, Weld and Delete are all next to one another, which is handy when modelling organic surfaces!
    band saw also selct "old" polylines
    well if you need points selected :
    i use this tool
    sel_point_chain
    http://plaza17.mbn.or.jp/~PICTRIX/index2.html
    "Will select points based on the direction of the first two selected. Deals with a variety of error conditions which stop other similar plug-ins from completing selections."
    LW70 LW75 Intel Mac lwfree lwmod
    Lightbulb hehe
    may be poz extender is good(I think so~~)
    But,it can't work at 7.5b.Because the new Lscript.
    it 's a .lsfile.
    so that it working a bit slow at a heavy polygons model.
    Now,I use the FI'...Extender..it works good~~moreover,
    it's a .p file.
    poz is now DI2
    poz .ls goes .p and with soem new features
    it need no longer clockwise selction you can lassoing the points!
    and when you selct a polygoen it will bevil this.
    fl#s will trace for the edges in the case of polygone selction.
    c.d.
