Thread: flipping a number using expressions
    Oct 2005
    Canada
    107
    I want to have a morph map drive the opacity of a texture, currently when i use a channel expression to link the two everything is fine and dandy accept when my morph map is at 100% my texture is at 100% opacity as well. I actually want the reverse behavior, when my morph is at 100% i want my texture to be at 0% and when the morph is at 0% the texture would be at 100%. I have very little experience with expressions.
    NewTek Developer jameswillmott's Avatar
    Dec 2004
    Gold Coast
    3,171
    Quote Originally Posted by larkis View Post
    The expression for the texture would be 1-MorphMap
    LightWave3D training, assets, news and discussion at www.liberty3d.com
    My opinions are my own and do not represent the opinions of any other entity, Liberty3D is not officially endorsed by NewTek.
    Oct 2005
    Canada
    107
    Cool, I will have to try this, it sounds a lot simpler than the solution I found. What i did is this: mapRange([object.MorphGroup.morphname],0.000,1.000,1.000,0.000) and attached that to the channel of the surface. Seems to be working.
    Thanks for the reply.
    Engineer/Entrepreneur Sekhar's Avatar
    Sep 2005
    Pasadena, CA
    2,124
    If you have 9.x, check out nodes too - they're so much easier.
