Page 4 of 29 FirstFirst ... 2345614 ... LastLast
Results 46 to 60 of 425
Thread: Radiosity, animated
  1. #46
    Quote Originally Posted by pooby View Post
    I don't know what you have in your shot, but if it has anything deforming -ie bones etc, then it is not supported by LW's interpolated radiosity. The animation cache will work only for animated 'solid' geometry
    I think that's only one of the two types of radiosity - final gather, but monte carlo works?
    Confirmed -
  2. #47
    Quote Originally Posted by joelaff View Post
    If you still get noise then lower the threshold to 0.01. This will add another pass of AA. Though you may experiment with raising the RPE first (1 or 2 at a time), depending on whether or not you think the rest of the scene benefits from the AA, and how long each method takes.
    Adaptive of .01 will double your render times, with no appreciable results. Adaptive is not 100% efficient, which it would have to be in order to replace multiple passes of aa. 6 pass with .05 would be faster and better, things like textures will shimmer with only one pass. It's subtle, but you'd notice it if you compare the renders side-by-side. I've gone up to 12 pass with a visible improvement.
    Confirmed -
  3. #48
    With Lanczos you are really shooting yourself in the foot. That is like running an unsharp mask after each AA pass and then expecting it to remove the noise. Ever try an unsharp mask on a noisy image with no threshold? It looks like garbage.
    Totally agree. Seems that professional print people use it, but I can't understand why - it puts a white halo around sharp areas of the image - blah!
    Confirmed -
  4. #49
    Neither work, but Monte Carlo will work if you dont interpolate it. However its much slower than Fprime doing the same thing.
    http://www.newtek.com/forums/image.php?type=sigpic&userid=18493&dateline=130857  4707
  5. #50
    Quote Originally Posted by toby View Post
    I don't find it doubles the render time, and it definitely has an appreciable result with radiosity. Try it out. You will see significantly less noise. More samples...
    As for textures. I start with a base AA of 1. If I have texture issues I will increase it. Though I might try blurring my texture first...
    Note, however, that I do NOT subscribe to the ridiculous notion that MIP mapping and pixel blending should be disabled. Some newer "schools" for 3d seem to teach this as some matter of fact. IMHO, they have never done any real production and don't realize that MIP mapping is there for a reason (to prevent texture shimmer, etc.). I have gotten objects from freelancers where they turn off MIP mapping automatically (they told me to in school). These cause all sorts of problems that they then waste time and processor power fighting with AA. Most of the time texture aliasing issues are a result of disabling this feature...
  6. #51
    This is what I used to think, but while they are post filters, they use 3d data, which you can't do in post. These two images are 1 pass aa with no adaptive, classic vs. gaussian. Guassian only took one-tenth of a second longer, and it would take several passes for classic to match it. This only works with the perspective cam, with classic cam it is just a simple blur.
    Note I would never use Classic without Oversample. (0.5-1.5 depending).
    Fine textures need more AA passes than a simple cube. The oversampled version looks comparable to the gaussian.
  7. #52
    VFX CG Supervisor Mike_RB's Avatar
    Vancouver
    2,184
    mitchell is my favorite AA filter, in all apps.
    my personal company: http://www.elementvfx.com
    the people I've worked for: http://www.theembassyvfx.com
  8. #53
    But you see that the reconstruction filters are not just a post blur right?
    Oversample (1.5 here) is more similar to a post blur than the reconstruction filters, and took a full second longer. This image looks exactly like one with jaggies that was then blurred in photoshop. Gaussian also softens textures, and it's what they use on big-budget movies so that's good enough for me
    Confirmed -
  9. #54
    here's Lanczos with it's horrific white halo
    Confirmed -
  10. #55
    You're right, it's phorked. Took a half hour to render a deforming box at 480 res.
    Anybody try using motion blur passes to reduce flicker? I'm having some good results with just 4 passes
    Confirmed -
  11. #56
    Scene Destroyer DrStrik9's Avatar
    May 2007
    Portland, Oregon
    1,684
    Hey toby, thanks for the poop on Gaussian.
    That recon filter could help defeat some noise, yes? It seems to complete the AA job nicely as well.
  12. #57
    Quote Originally Posted by DrStrik9 View Post
    Actually I'm not sure it'll fight noise anymore than other types of aa. It uses geometry data to work it's magic, so it only works on edges. Noise and textures still need more aa.
    Confirmed -
  13. #58
    I would appear they are not purely post blur, yes. I would like to get a better clarification from Mark Granger. In another beta thread he said they were "basically" post filters. I would be interested in knowing precisely how they tie in technically.
    Oversample is not a post blur, though. According to Granger it blends the existing sample with surrounding pixels based on the current sample's position within the pixel (samples are subpixel).
    I assure you that not all movies use Gaussian... It tend to use Gaussian in mental Ray, but MR works differently, and you can control the radius of the gaussian.
    No doubt that Lanzcos and Mitchel, which both provide sharpening (i.e. white and black halos) are bad news, esp for animation. Sharpen after the render if you need to...
    Obviously different subject matter and lighting techniques require different rendering techniques.
  14. #59
    May 2007
    Portland, Oregon
    1,684
    Visible Impressions
    I never expected such participation in this thread. Thank you. I have learned HUGE amounts of stuff (not that I get it completely).
    I think I feel just a little bit cynical at this point, about GI in general, at least for animation. I still dig Except's perspective though on interpolation, and he gets great imagery, animated. So it's possible. :-) What I need to do is begin to develop some content, and learn about all the new lights (wow!), and the still-elusive node editor. Then I'll add GI in appropriate situations, when needed, and only when it works. This has been a great priority lesson for me. :-)
    You guys are awesome.
    Michael
  15. #60
    Done more tests, looks like motion blur only minimizes flicker, can't seem to get rid of it, unless maybe if it were set high enough to take much longer than other methods.
    Let's set the wayback machine for 2006, when Kray rendered this anim, with something like 8 bounces, no cg lights, no cache, in about two minutes a frame, and with deforming geo.
    http://rapidshare.com/files/238721850/DrunkenZombie.avi
    LW hasn't even caught up with that yet.
    Confirmed -
