Thread: Problems with Hub since SSE2 install
    Registered User jpleonard's Avatar
    Apr 2007
    mississippi
    107
    Hello everyone. Has anyone else ran into an issue with the hub working? I installed the SSE2 version of lightwave 9.6. I wanted to use a couple of plugins that were 32-bit, anyhow, I had a project with a large scene come up and had to install the 64-bit version and now hub crashes on start up. I've uninstalled and reinstalled several times, deleted all my content from my pc, removed all lightwave related cfg files, I even went as far as deleting all entries that were lightwave related from the registry manager. Still hub crashes on start up on 64-bit. I can reinstall 32-bit SSE2 version and hub works, but Layout crashes repeadedly about once an hour or so, especially when cuastics is activated. Any ideas?
    James
    Window Vista x64 AMD Athlon 64 X2 5600+ 4GB Ram nVidia Verto 8600 GTS
    not sure,
    this worked for me though,
    http://www.newtek.com/forums/showpos...01&postcount=5
    Apr 2007
    mississippi
    107
    I figured it out last night. I finally reinstalled the SSE2 version again, and copied and pasted that cfg file for the hub in renamed it to LWHUB-64.CFG and it's working fine now, even after uninstalling the 32 bit SSE2 version. Thanks for the link though. I'll check it out anyhow.
    James
    cool
    yep, there has been a couple of reports on the hub not working in 9.6...
