Results 1 to 9 of 9
Thread: Lower Third Count Down
    Talking Lower Third Count Down
    Does anyone have a lower third count down timer available? We are having a large church gathering the end of May and I will record an animated slide series of announcements for play between meetings. I would love to have a lower third count down to play for the last 10 or 15 minutes over the slides.
    Daniel Davis
    Media Ministries Coordinator,
    Madison Campus SDA Church
    Dec 2002
    San Antonio, TX
    3,830
    There's a time-code overlay that could be used.
    Don't stream it - TriCast it!
    How does it work?
    The instructions included in that zip file talk about how to use this in the editor. What I want to do is put something like this into the text for downstream key. Any ideas?
    Daniel Davis
    19,376
    Apply the timecode file as an overlay in the editor, sizing and positioning to to taste. Reverse it, so it counts down. Render the duration you need using the AVI with alpha preset, and run it in the DDR.
    May 2009
    Midwest
    1
    Dear Paul, I think I need this, but first need to understand more about time-code-overlay. Where can I find out more (for a beginner)? Jack
    Reverse the Time Code???
    I just tried to figure out how to do this and could not find any way to make the instructions work. I would love to be able to make a lower third count down that goes down from 10 minutes!
    Daniel Davis
    19,376
    There is another discussion about reverse in the forums, but suffice to say that TC's Edit Media does not have the "Reverse" function. However, there are ways to accomplish it using other means. Probably the simplest is to put the clip in a DDR, trim it to taste, and play it in reverse while recording. The recorded file will be reversed, and can be further trimmed for precision.
    DDR in Reverse???
    Please help me, I'm blind in one eye and can't see out of the other! I am missing the "reverse" function in the DDR!
    Daniel Davis
    19,376
    Please see your other post on this topic for a reply. (As you have a VT, you have other options.)
