Page 1 of 5 123 ... LastLast
Results 1 to 15 of 65
Thread: Golf Ball
    Mar 2008
    Prince Edward Island
    492
    Golf Ball
    Hi. I am trying to create a golf ball. I thought it would be fairly simple...Boy was I wrong!!
    I tried the tutorial at this link:
    http://www.newtek.com/forums/showthr...ight=golf+ball
    No Luck. I get it looking not bad in Modeler, then i send to layout to have a look see and not to good.
    See attached.
    Anyone know a good work around?
ID:	69530   Click image for larger version.
    Cow Orker cagey5's Avatar
    Manchester UK
    3,273
    You've gone wrong somewhere. If it's modelled correctly it renders fine, so it's not really a work round you need. How many times have you attempted this? You get the same result everytime?
    Forum Tips
    If English is your first language, you should know it's 'losing' and not 'loosing'!
    Mar 2008
    492
    I have been on it for a few hours now and the same results.
    Mar 2008
    492
    Golf ball
    Hi have submitted a post in the 9.6 Discussions to see if there are some solutions.
    The attached is where I am at. It looks like very low resolution.
    Mar 2004
    Northern New York
    5,254
    Would you mind showing a screen grab of the wires from modeler as well as a screenshot of the surface editor. Do you have this subpatched? It doesn't look it, but I thought I would ask anyway.
    Silk
    Mar 2008
    492
    Here are the screen grabs for two o fthe models I am working on. Also attached are the actual models and a photo of a good golf ball image.
    Attached Files Attached Files
    Mar 2004
    Northern New York
    5,254
    Well I have been playing around with this idea. What I came up with is create a ball using tessellation. In the background creat a small ball about the size you want for the hole. Before switching the small ball to the background run Multiply>Duplicate>More>Particle clone. This will place the small balls around your golf ball (May take time to create them) Now put the newly created small balls into the background and run boolean subtraction. Merge points and render.
    This image is similar to how it would look. Hopefully you would spend more time than I though, lol.
    Silk
    borkalork BORKALORK! biliousfrog's Avatar
    Dec 2003
    Lowestoft, UK
    2,488
    I've just had a quick look at the tutorial and your models...I think that the problem is that you've moved in more than just the centre point of the holes which has caused that sharp, hexagonal ridge. I also think that you've missed a step or done something in the wrong order because the indentations are 'puckered' rather than hexaginal.
    Mar 2008
    492
    Hi. Quick message to SilkRooster.
    Is it possible for you to show some step by step screen grabs?
    Also I tried loading Particle Clone in 9.6, but it is not showing up.
    I only see Point Clone Plus.
    Super fast way to make a Golf ball:
    >Create a ball Tessellation set to 6
    >Use rounder on all points
    >Using Stats panel select all Ngons
    >Bevel with a small inset and a small shift in
    >use the Spikey tool to shift in one more time
    >hit Tab and your done
    Here are the steps saved out...
    Mar 2008
    492
    Thanks, but it still isn't working.
    I created a Tessellated ball set to 6.
    When I go to Rounder nothing happens and in the Stats panel there are no NGons.
    Mar 2008
    492
    Hi William. I forgot to ask; what are your rounder settings?
    depends on the size of the ball. make sure rounder is set to points and you have to click in the view port and then click and drag to set if you want to do it interactively.
    Mar 2008
    492
    Ok. That works, see screen shot, but I still do not see the NGons in the Stats window.
