Results 1 to 9 of 9
Thread: Beta Version and Forum
    Sep 2006
    Aue, Germany
    29
    Hi
    How can i get access to the newest LW Beta and the Beta section of the Forum?
    Dec 2006
    Philadelphia, PA
    5,738
    you need to register for the beta first, at the registration page:
    http://register.newtek.com/ (I'm not sure if there is a different registration page for Germany.)
    Once you register you should get set up for the beta forum (it appears at the bottom of the fourms) but it can take a few days for it to happen. If you don't get access in a few days I would email someone at NT support and just check the status of the beta forum access. Once you get the beta forum access there are a bunch of threads that will help you get set up and get the beta installed if you are having issues.
    ps. sometimes it helps to sign out of the forums and then sign back in to see if you get the access to the beta forum at the bottom (after you register).
    Jul 2006
    Albuquerque, New Mexico
    11
    Codec?
    I've run into a snag and I wonder if someone would help me out. When I learned LW at school (7.5) you could just download a codec such as DivX, Quicktime, Xvid, whatever, and as long as you had the free download of that LW would include that codec for animation. However, that doesn't seem to be the case anymore. I was going to just puchase DivX and Quicktime Pro versions in hopes that the appropriate plugin would be available to 9.5+beta, but I thought I would ask before I bought.
    Help appreciated,
    Gary
    Dec 2006
    Philadelphia, PA
    5,738
    Gary, to be honest, it's always best to render to sequential frames using a lossless compression on the frames, such as PNG, TGA, TIF, etc. And then after rendering re-compress into a movie file of your CODEC choice. This will let you avoid many problems and also let you try different compression settings without having to re-render every time.
    Evil Bastard Incorporated
    Head Office
    400
    Like Jeff said, never ever render direct to an avi or mov, if your machine crahes halfway through you've got to start all over.
    If you don't have video editing package there are some very good cheap ones available these days.
    This little chapter in history is over, ended, finito, no more, an ex chapter.
    Jul 2006
    11
    Codec2?
    Thanks for the replies! I guess I didn't state my question clearly. Of course saving out frames is a good idea in any event (backing um up too! ), but my question is a little different.
    If you go to the Render Panel and then checking "Save Animation" next you input "Type" you're presented with a set number of formats (4X Storyboard, Avi (.avi), Direct Show (.avi), etc., that you could render in directly.
    Those settings are put there in the form of a plugin which you can find under the Edit Plug-ins under Animation I/O. This is the difference I'm talking about. Lightwave 7.5 use to just be able to access the codec directly. For example: If I were to install the DivX codec I could just render out to that format because the codec already has the read/write information imbedded. I'm not positive but in the editing packages I believe that's how they still work. In any event I didn't know if you could obtain say " mov.p or DivX.p or H264.p, etc. I couldn't find any reference in the LW 8.5 or the LW 9 - 9.5 Manuals and addendum concerning any of this...
    Gary
    Pessac
    5,060
    No, it didn't. It was the same - you had AVI and you chose DiVX from the options menu.
    B
    LightWave 3D Trial Edition
    Pessac
    5,060
    B
    Sep 2006
    Aue, Germany
    29
    Now i have access to the Beta Forum.
