Thread: File Comments
    File Comments
    I know I should know this, but I'm wondering if anyone knows how to set a file comment -- the type you can read by right-clicking a file in windows and looking at the properties tab...
    Thanks!
    Simon
    PS And is there a MacOS equivalent?
    aka Ken9 DuneBoy's Avatar
    Sep 2005
    Los Angeles, CA
    280
    That data is stored in an NTFS Alternate Data Stream (ADS), here are some links that should be helpful.
    http://www.forensicfocus.com/dissect...hidden-streams
    http://members.cox.net/slatteryt/Streams.html <- This one has info about the Summary tab's use of ADS.
    http://support.microsoft.com/kb/105763 <- A bit of c source code.
    http://technet.microsoft.com/en-us/s.../bb897440.aspx <- An ADS utility.
    http://en.wikipedia.org/wiki/Resource_fork <- Info for MacOS
    Unless you're talking about the data that's in the Version tab of an exe or dll. That's compiled in as a resource. Here's some MS info about the VERSIONINFO block:
    http://msdn.microsoft.com/en-us/library/aa381058.aspx
    Usually that data is set via the IDE.
    Ken Nign
    Thanks for the suggestions, but I may have led you astray.
    The attached image should show what I'm referring to...
    Simon
    Sep 2005
    Los Angeles, CA
    280
    That's right, that tab uses an Alternate Data Stream for its data. Except for certain file types where it actually comes from inside the file, namely MS Office files in which case a special handler is used to read/write the file's data instead of using an ADS.
    Ken Nign
    Thanks once again.
    Having taken a look, I've chickened out of that approach, in favour of writing comments to a log! At least that will make the Mac compatibility a lot easier!
    Cheers,
    Simon
    BTW, have we met? I occasionally manage to get to the LA user group meetings...
    Sep 2005
    Los Angeles, CA
    280
    I know how you feel, I considered using ADS when I was writing Info Saver but also opted for a .txt file.
    I've seen you at a couple meetings, and I was at Harry's the last time the Users Group met there for dinner (I sat next to Jessica). I remember the waiter asked if you wanted fries with your Fish 'n' Chips. Next time you're at a meeting I'll be sure to introduce myself.
    Ken Nign
    Fórum áss clówn Hopper's Avatar
    Jan 2005
    Austin
    3,393
    ADS can also get you pretty screwed if you use it for purposes other than its original intent.
    If you copy a file with and ADS entry to another file system that is not NTFS, you will lose the ADS portion.
    BUT...
    It sure is a good way to hide things... I used to use it to xfer passwords.
    Playing guitar is an endless process of running out of fingers.
