Thread: Registration is down
    Stuff
    Nov 2006
    Amherst Nova Scotia
    988
    I mentioned this in another thread, just wanted to make sure it gets seen by NT.
    Registration "my products" or "downloads" returns the following error:
    Server Error in '/' Application.
    SELECT permission denied on object 'tblRMA', database 'NewTek', owner 'dbo'.
    Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
    Exception Details: System.Data.SqlClient.SqlException: SELECT permission denied on object 'tblRMA', database 'NewTek', owner 'dbo'.
    Source Error:
    An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
    Stack Trace:
    [SqlException: SELECT permission denied on object 'tblRMA', database 'NewTek', owner 'dbo'.]
    System.Data.SqlClient.SqlCommand.ExecuteReader(Com mandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream) +742
    System.Data.SqlClient.SqlCommand.ExecuteReader(Com mandBehavior behavior) +44
    System.Data.SqlClient.SqlCommand.System.Data.IDbCo mmand.ExecuteReader(CommandBehavior behavior) +5
    System.Data.Common.DbDataAdapter.FillFromCommand(O bject data, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +304
    System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +77
    System.Data.Common.DbDataAdapter.Fill(DataSet dataSet) +38
    OnlineReg.DataLink.spProductRegistrationDataLinkby Cust(Int32 intCustomerId, Int32 intVersionId)
    RegisteredProducts.RegisteredDL.DisplayDLCustomerW ise()
    RegisteredProducts.RegisteredDL.Page_Load(Object sender, EventArgs e)
    System.Web.UI.Control.OnLoad(EventArgs e) +67
    System.Web.UI.Control.LoadRecursive() +35
    System.Web.UI.Control.LoadRecursive() +98
    System.Web.UI.Page.ProcessRequestMain() +750
    Version Information: Microsoft .NET Framework Version:1.1.4322.2407; ASP.NET Version:1.1.4322.2407
    Andrewstopheles
    We've got it simple. Jim_C's Avatar
    Thee cool evening breezes of Anytown, USA
    4,028
    Bumping this....
    Bad timing for this to happen for us....
    ack....
    Stuff
    Nov 2006
    Amherst Nova Scotia
    988
    its working again right now
    Andrewstopheles
