Thread: where is spin quad tool
    Feb 2006
    santa monica
    238
    can any one tell me where is spin quad tool, I can not find it
    Simon
    Oct 2003
    Orlando, FL
    4,164
    Should be on the detail tab.
    Look under Polygons
    Merge Polys
    Flip
    SpinQuads
    Hope this helps
    Fórum áss clówn Hopper's Avatar
    Jan 2005
    Austin
    3,393
    Or you can use the shortcut... Ctrl-K (if you haven't reassigned it from the default).
    Playing guitar is an endless process of running out of fingers.
    Registered User aSkeptic's Avatar
    May 2006
    caledonia ohio
    155
    If you go into Edit:menu layout, there is a button labeled search which you can use to search for a menu function. Once you've got the name of the function correct you can use the find button to locate it within your current menu layout. If you still can't find it, you can put make your own menu entry by dragging and dropping in the menu item in which ever menu you desire.
