Thread: Bump map and car paint
    Oct 2005
    Canada
    107
    I'm trying to get the car paint material in the node editor to accept a bump map. I have a grayscale image i did in photoshop that needs to be mapped on the model using UV's. When i make an image node and load the image and connect it's bump output to the bump input on the car paint material node nothing seems to happen. When i connect the same image node to the bump on the final surface node it works.
    Is there something specific i need to do to get the actual car paint material node to accept the bump ?
    This might be a bug, but in any case, the car paint material is only available in the 9.5.1 beta and this ought to be discussed in the beta forums.
    8x2.8 Mac Pro, 8 GB RAM, Radeon 2600XT, Mac OS X 10.5.6 (previously: G5 Quad)
    Caution: tech-savvy artist in full-on geek mode. May obsess over technical challenges until solved.
    Oct 2005
    Canada
    107
    And where are the beta forums ?
    Registered User Wopmay's Avatar
    Jan 2005
    Los Angeles
    295
    Quote Originally Posted by larkis View Post
    Sign up for Open Beta on your registration page and the beta forums magically appear at the bottom of the forum topics.
    There's a value named Paint Bump Height that by default is set at 0%. Clearcoat Bump Height is by default 100%. Depending on your setup, you might need to set a value for the Paint Bump Height.
