Thread: Morphs not working
    Newbie Member Eye Bleed's Avatar
    Sep 2008
    Orlando, Florida
    36
    Morphs not working
    Hi, I'm in a situation where my morphs are not working. I don't know why but they just don't show up in the morph mixer, I have replaced the object with the current one and even tested to see if it had the morph in modeler. Layout shows the list of morphs in the mixer, but not the sliders I am working with 9.5 but I'm totally stumped. Please Help
    Technical Account Manager
    May 2006
    Texas
    172
    From what I understand you can see the list of endomorphs under the left-side of the Morph Mixer, the Morph List but on the right-side you see no names, sliders, values or buttons, correct?
    If so, the first thing I would see is if you can duplicate this on a new, simple object. Create a box, a simple endomorph then save it. Name the object and the endomorph short, one-word names for simplicity's sake and try to load it into Layout (complex names like object.morph as a name for instance would create a group and a morph under that group). If you can still recreate the problem here right off the bat then try deleting your configurations.
    To do this close Layout and Modeler and then go to C:\Documents and Settings\Your user profile and delete the following files (C:\Users on Vista) (you don't need to delete the files, just move them from the folder if you don't want to lose all your configurations just in case):
    LW9-64.CFG
    LWEXT9-64.CFG
    LWHUB9-64.CFG
    LWM9-64.CFG
    Restart Modeler and Layout and try to repeat the steps above in creating a new model. You want a new model first before trying an old one so the problem doesn't potentially reintroduce itself.
    If you're still having problems please let us know what operating system you're on and post a zipped up object and scene file that you've been able to duplicate the problem with.
    Dan Parker
    I know stuff about NewTek stuff
    Sep 2008
    Orlando, Florida
    36
    Yes, thank you it worked when I removed the CFG Files , all is better
