Results 1 to 8 of 8
Thread: Display subpatch level? Ocean details better???
    Airwolf 3D man virtualcomposer's Avatar
    Jul 2008
    Castle Rock, CO
    1,440
    Just wondering, I really have never messed with the "Display subpatch level" in the properties panel and I want a really detailed ocean. One that doesn't look computer generated. I would rather spend an extra week in render then have a fake looking ocean. I was wondering if the DSL set to 12 is going to give me a much more detailed ocean then the default 3?
    Graphic Designer & 3D Textures
    -Mac Pro 2.26GHz | 8-core | 3TB HD | 12GB RAM | Dell Ultrasharp 2707 | ATI Radeon HD 5770
    Dec 2006
    Philadelphia, PA
    5,738
    The display level does not effect the rendered image at all. It just effects what you see in the viewports. So you can adjust it based on how fast your computer and video card are to adjust your viewport performance - and what you see as well.
    Your render level is what effects the resolution of the mesh at render time. And yes, that can greatly effect the final rendered image. Try a few different settings to see how they look: 1, 3, 10, 40, etc.
    Gribbly's Day Out flakester's Avatar
    Dec 2004
    Birmingham
    1,002
    Quote Originally Posted by JeffrySG View Post
    00ooof!! Render sub-patch level of 40! That might cause a bit of a pause before drawing anything!
    To my knowledge, fprime reads the 'display' sub-patch level only for it's geometry calculations when rendering, not the 'render' sub-patch level. Though I could very well be wrong there.
    flakester.
    Evil Bastard Incorporated
    Head Office
    400
    set display between 3-6 depending on the density of the subpatched ocean and render level between 6-12 again depending on the density of the original.
    The more dense the object the lower the display/render levels.
    'The more dense the object' sounds like some forum admins I know
    This little chapter in history is over, ended, finito, no more, an ex chapter.
    Dec 2006
    Philadelphia, PA
    5,738
    Quote Originally Posted by Andrew March View Post
    lol!
    Yes, each model will definitely have its own sweet spot for a render setting...
    Pessac
    5,067
    Also think about using APS so that you don't subdivide more than you need to. You can base it on distance to camera so that polygons far away from the camera are not subdivided as much as those close to the camera.
    B
    LightWave 3D Trial Edition
    Jul 2008
    Castle Rock, CO
    1,440
    B
    Hey that's good advice. Thanks. I never thought about the far away objects with less polygons.
    Try to keep Display and Render subD levels the same. When you don't, you'll see the spinning beachball (or timer) as LW re-calculates the entire subd mesh whenever you hit F9, and then again when it's done rendering. It's harmless, it just adds a lot of time to renders.
    And APS is probably the best thing that ever happened to ocean renders! ( I don't know if the above tip applies to APS )
    Confirmed -
