Thread: ankle goal
    Mar 2007
    Oklahoma
    32
    ankle goal
    when I parent my ankle goal to my ball of foot goal, the ankle goal shoots down the negative Y.
    Also, sometimes the mesh comes away from the bones and when I go back to zero and select all my bones and rest them, the mesh doesn't completely return to the bones.
    Im using 9.5
    thanks
    The goal problem is likely because you don't have "parent in place" on. That is o for options panel. If you move the null and then slecect perent, it keeps the local location of the null and then references that to the parent. If you select parent in place it keeps it there and calculates a new position based on the location from the parent.
    The mesh problem could be a couple of things. But for the r rest command. Be persistent. Do it again if you have to (Sometimes I do it 2 or 3 times) and make sure and key frame each bone in place at 0 as well.
    Mar 2007
    Oklahoma
    32
    great!!!
    thanks. Its always the simple or overlooked things.
