Results 1 to 15 of 16
Thread: All my yellows are green
    Amused
    Keeping Austin weird
    1,322
    I'm pretty sure my color sight is okay, but it seems to me that yellow renders as slightly green. I have to move over to light orange to get the darker shades of a yellow to stay out of green. Am I imagining things?
    And for the cat people here, I almost made the title: Awl ma yellowz iz greenz!
    Sep 2005
    Earth
    3,121
    maybe you ambient color is set to green?
    D a r t h W a v e r Nemoid's Avatar
    Italy the great
    1,388
    could be due to how shadows are treated by rendering engine ? however, I'd look to result if using a different light color works , go for it !
    Nemoid | Illustrator | 3D artist
    .::Creating for you::.
    Co-founder of
    www.lwita.com italian/english Lw forum
    Is your light blue?
    Blog
    Specs:
    Desktop: Q6600 Quad 2.4 ghz, 8GB, 8800 1Gb, Vista Ultimate x64
    Laptop: Core 2 Duo, 2GB, ATI craptastic video card, XP
    and some funny looking Mac's that I don't know much about.
    Italy the great
    1,388
    remembered you also can use coloured shadows
    Co-founder of
    Amused
    1,322
    Ambient isn't intentionally set to anything, but I'll double check. But even in Modeler in the surface editor, pick a yellow preset and look how the darker shades go to green. When rendered in Layout, even the lighter shades look greenish.
    Dreamer MooseDog's Avatar
    Mount Whoville, VT
    1,438
    what color is your parachute?
    We are pirates, we are artists...
    Blog
    Super Member Nangleator's Avatar
    Sep 2007
    Massachusetts
    2,123
    I've always had people tell me my gold looks greenish. I'm color blindish, so I thought that was the problem...
    Could be your monitor. Check out a monitor calibration website like this one
    http://www.imaging-resource.com/ARTS.../CALIBRATE.HTM
    But I'll bet it's just the natural way we percieve colors. If you have no color in your lights and/or fill lighting, yellow will fall of to green in the same way that blue turns to violet when desaturated; (see attached) to me, this looks greenish at the terminator.
    The trick is to not use perfect primary colors, they don't occur in nature, and they're less attractive anyway. In cases like the this where yellow falls off to black, you're basically mixing yellow with plain grey. Blue skies look wrong without some green, and yellows look 'unripe' unless there's more red than green in them.
    Confirmed -
    The image viewer lets you quick check any color in your render by just holding down the mouse on the desired area and reading the R G B values in the viewers title bar. R G B space is additive so Green will be
    – R 0% G 100% B 0%
    and Yellow will be
    – R 100% G 100% B 0%
    When I did a test and took a pure yellow and green patch out of Photoshop even with a pure white ambient value and a neutral grey BG color I still got around 10% or so noise from the other colors but if you're color blind a quick check like this should help give you confidence in you color management skills.
Name:	YELLOW _&_GREEN.png
    Quote Originally Posted by gerry_g View Post
    – R 0% G 100% B 0%
    and Yellow will be
    This is interesting, why do you think you're getting negative values? You've got more than just ambient light here, what are the sufaces like? You're using reflection and / or radiosity?
    As far as noise, having Dithering on can cause that too. If you're going for pure colors that should be off.
    Confirmed -
    This is interesting, why do you think you're getting negative values? You've got more than just ambient light here, what are the surfaces like? You're using reflection and / or radiosity?
    Well mostly due to the fact I'm dim, I loaded an existing file without checking all the the parameters, when I did check it over several of the lights were off white and one was pale blue, also the map had a gamma value of 120% (which is a typical set up for me but no good for a test). No dithering no radiosity (other than BG Radiosity) just reflections and shadows, even so when everything is corrected out there is still some stray color and I presume everything is adding up to more than a 100% because I don't have clamp values checked.
Name:	YELL)W GREEN_2.png
    Sep 2007
    Massachusetts
    2,123
    I'm not terribly color blind, but I've gotten used to all the tools. My coworkers don't even know.
    Thanks, Toby, I discovered a long time ago that very saturated colors don't feel very real in a texture. I hadn't realized that pure primary colors probably look even more fake.
    Amused
    1,322
    I appreciate the discussion guys. A little over my head at the moment, but I'm looking into it.
    I doubt that radiosity can ever give you results with no detectable noise, that's partially what makes it look good/more realistic actually. And using it with a grey background will introduce all the colors, that's where the blue values are coming from.
    Confirmed -
