Results 1 to 8 of 8
Thread: Using transparency map in a conductor material node?
    Feb 2005
    Barcelona
    310
    I am trying to do some perforated aluminium using conductor but the tranparency chanel is being ignored. Is there any way of doing it or should i just use as a clip map on the object layer?
    Thanks!
    Registered User PhantomPhish's Avatar
    Feb 2008
    In the phishbowl
    138
    Use Material Mixer, feed the Conductor node into one input and a Delta material set to 100% transparent into the other. Control the Alpha input with your transparency map.
    Dec 2004
    London
    4,502
    Since metal is never ever transparent, the Conductor material doesn't simulate transparency. Use a Standard material with everything at zero except the transparency, and plug that and your Conductor into a Material Switch node. Then use your transparency mask to switch between transparent Standard and opaque Conductor.
    Hello Inaki, btw.
    edit: Material switch renders more quickly, but behaves more like a clip map (no softness).
    Are my spline guides showing?
    Feb 2005
    Barcelona
    310
    I used the material mixer as it was easier to make it work... could not make work the material switch... may be too much Simon?
    Thanks anyway!!!
    Not really real...
    May 2003
    Pahrump, NV USA
    39
    Quote Originally Posted by Captain Obvious View Post
    Since metal is never ever transparent, ...
    What about transparent aluminum, huh? It may still be a number of years too early, but...
    http://www.rense.com/general20/transparentalum.htm
    http://www.af.mil/news/story.asp?id=123012131
    bart
    Creative Director jaxtone's Avatar
    Sweden
    1,482
    News to me
    BTA1701!
    Thanks for the info... good to know when building airplanes
    Curious
    Feb 2005
    Barcelona
    310
    the discussion is served...
    Dec 2004
    London
    4,502
    Quote Originally Posted by bta1701 View Post
    bart
    Neat. But how the hell does that work, exactly?
