Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: PolyMove Node for rough crowds perhaps ?
    areté adk's Avatar
    Melbourne
    1,505
    as in Aussie rules mobs
    G'day folks ...
    I'm pretty much a node virgin but thought some here might be interested in this and take it a little further perhaps. It's come about with me messing about with HD instance and trying to get a little variety in the movement of the polys where HD instances are placed. All movement / rotations of the polys are based on greyscale images images (applied to the ground for visual reference). There are only 2 objects in this scene ... 1 poly for ground and 1 layer with the red walkers that do their thing.
    All thanks to Denis P. for the PolyMove node plus all the others I use ... we owe you big time. Oh and lets not forget Antti of course
    PS: Will upload the scene for anyone who's interested as soon as I can...
ID:	62483   Click image for larger version.
    Attached Files Attached Files
    areté adk's Avatar
    Melbourne
    1,505
    ...more
ID:	62488   Click image for larger version.
    areté adk's Avatar
    Melbourne
    1,505
    ...more still
ID:	62492   Click image for larger version.
    areté adk's Avatar
    Melbourne
    1,505
    ...last one
    Super Member JMCarrigan's Avatar
    Dec 2006
    Newport, Oregon
    2,008
    Hmmmm. Very interesting!
    J Michael Carrigan
    I just had an attack. Malware.
    But now I have a DESKTOP from Xidax. Not the best but pretty dang good.
    areté adk's Avatar
    Melbourne
    1,505
    Here's the scene folks ...
    What I'd like to figure out / play with is how to clamp limit rotations + get something that resembles obstacle avoidance. They "kind" of do it now but in a very rough and unpredictable way ... All I know is I'm way to old to be resurrecting my engineering degree maths ... I think it's actually permeated out of my head to be honest. I'm sure someone out there can do this more justice then I can at this stage. I have a feeling this can be pushed to do quite a bit more but I'm not really in the best place to know if that's possible or not ?
    PS: Apologies as some of those MOV's don't scale to well .. if the walkers don't appear to be doing anything it's cause they are rotating
    interesting,..
    can be combined with this one
    http://www.newtek.com/forums/showthr...t=86338&page=7
    can be combined with MarkerPen also,...
    http://www.newtek.com/forums/showthr...096#post801096
    areté adk's Avatar
    Melbourne
    1,505
    If you mean combined with HDI erikals that's exactly what I was wanting it for. A few random variations to the speed / heading of the walking clones.
    Was just trying a few creative ways of animating people walking down streets / paths and around corners etc. without too much hand animating.
    As for this working with marker pen... am yet to give that a go but thanks for the heads up.
    interesting,..
    bumpedi bump...
    i wonder, could this be use to make e.g. ants crawl around the backside of a tree and the branches as well?
    areté adk's Avatar
    Melbourne
    1,505
    Heya erikals,
    Actually, something that I posted here that serge solved ...
    http://www.newtek.com/forums/showthread.php?t=105308
    ... gave me the idea that perhaps this could work in other situations. So I just gave it a quick go and it seems to work ok (needs further work I reckon).
    Again this is just two layers, trunk & ants and I wanted the ants to "stick" to the trunk as they move up. I roughly animated the ring of ants (ANTS_01.mov) then applied serge's idea (but across 2 axes) - which kind of creates a hybrid "sticky" I guess. Result is ANTS_02.mov.
    Not sure how much further you can tweak it (there's places where they don't stick 100% as you'd expect ) or layer this with my image idea above in order to produce what you need. Here's the scene anyway and see if it helps & how you go
    Cheers .... adk
    thank you for the videos and files.
    i did some testing, but couldn't get the results i was aiming for.
    one of the problems is that it doesn't seem to stick properly..
    the more i though about the challenge, the more i got to the conclusion that dynamics were the way to go. however, even with dynamics ants crawling on a tree, spitting in groups onto different branches seems like a tough task.
    i almost had a solution, but i hit a wall when trying to think of a solution to track pixels in 3D.
    is there any way to morph baked particles?
    May 2006
    France
    3,966
    ...is there any way to morph baked particles?
    1-Morphs & Endomorphs are point vertex maps, so you need points.
    2-Particles are not points, no geometry.
    3-Transformed Particles in Partigons, are points but cloned on
    the fly, so in Modeler a Partigon object has geometry but only
    one point.
    4-Particle Scan is a way to baked calculated dynamic particle
    in a MDD file, it create also the cloud of point as a separate
    LWO file, but don't ask me how you could set the transition
    between a MDD node and a Morph node...
    http://pagesperso-orange.fr/dpont/pl...#Particle_Scan
    Denis.
    Edit: You would need also a different way to link objects
    to points instead of particles...
    Denis,
    Quick question. We don't have an option now to get 'spot info' from another object. For example, could there be a possibility to open the node editor for object#1, and have 'spot info' from object#2. This way we could measure for example the distance between object#1 and the nearest spot of object #2. Does this make sense?
