Thread: slight problem
    slight problem
    Hey all, I've been rattling my brain about this for quite some time now, I've got this mechanical spider and its in two segments with wires and tubes in the middle. The back and the front move independantly, but what i have a problem with is the wires in the middle. i need each end of the wire to stick to each segment and i want to use motion designer on the wire in the middle. so how can i stick each end of the wire onto the segments?
    Thanx in advance for any help
    The Netherlands
    175
    hi there!
    I don't know much about motion designer, but I know that worley labs (check http://www.worley.com) has a plugin for this type of animations...
    LightJustice Panikos's Avatar
    Nicosia Cyprus
    1,727
    Worley - Taft Hoser
    Dance Commander WCameron's Avatar
    Wilmington MA
    546
    to use Motion Designer in that way I believe you'd have to
    physically attach the end of the wires and tubes to the leg
    geometry.
    second to Hoser - which has kinda a weird setup process in that the geometry has to be at 0,0,0. check out:
    Shift Spline Transform:
    http://www.shift.gr.jp/html/staff/sp/sp000003.html
    Uses a spline to deform geometry in layout. you'd
    have to Keyframe the tubes or set up some kind of expresion...
    Rope Rig:
    http://mapage.noos.fr/samuelLK/Plugi.../Tutorial.html
    depending on the scene and setup it might be better to use
    Bones (Rope Rig) and either hand animate any dangle or
    sway of the ropes or use Effector nulls or somehting along those lines.
    - Will.
    "All those with Psychokinesis, raise my hand."
    - The Doctor.
    The Room With No Doors
    by Kate Orman.
    check this thread
    http://vbulletin.newtek.com/showthre...7541#post57541
    A simlar technique may work. Use a ribbon stand-in to get the calculations, save the .mdd file and use the MD meta plug in displacement to apply it to your real object.
    Works great and will be really easy in LW8.
