Thread: Help! Module windows open off the face of the earth
    Cartoon-based life form mgrusin's Avatar
    Boulder, CO USA
    780
    Unhappy Help! Module windows open off the face of the earth
    Yo Toasterinos!
    I had to move my VT (3) off its hi-res dual-monitor setup onto a single monitor for a field job. The resolution of the new monitor is 1024 x 768, which should be enough for this job, but now when I try to load some of the modules, e.g. the switcher, it appears, or more to the point doesn't, off-screen. Boo! Is there a way to get these to either start in the visible area, or move to the visible area? I've tried everything I can think of (reset window positions, etc), and even (*gasp*) RTFM but so far no joy.
    Thanks for any help! -MG
    Bloomington, IN
    1,614
    Look in the VT directory for "Oops I Messed Up My Config Files.bat" and double click it. This will reset all the modules configurations to default. Should solve the problem.
    -Jeff
    My TriCaster Blog
    TriCaster Tally Lights
    Boulder, CO USA
    780
    Belated thanks for the help, but I don't think that would have done it. I did fix it, and now know the problem stems from my monitor / screen resolution, which wasn't high enough to show the default window positions. Which is an unfortunate feature, since for what I wanted to do, that lowish screen resolution was fine.
    I fixed it by fooling the monitor into running at a higher resolution, even though it complained mightily (yes, I know this can hurt a monitor). Then I was able to move the switcher window into view and go back to a lower resolution.
    Problem solved, thanks! -MG
