Results 1 to 2 of 2
Thread: ARGH! Forgetting is the HARDEST part!
    I've been having trouble with 8.5 at work. Right now, it's forgetting the menu layouts and a few select plugins/lscripts (Bandsaw/TrigonsX, respectfully.)
    I set the menus & key commands to my liking with my .cfg files, load the plugin & lscript, close normally...and when I re-open Modeller, I'm greeted with the fershluggner default menus and keys!
    (I'm running on an OSX Mac, if that helps.)
    Why is Lightwave getting selective amnesia?
    More info: About 2 weeks back, 8.5 at work just started 'force quitting' itself whenever I started it...for no apparent reason. I finally resorted to moving the existing LW folder to my Desktop & re-installing from the install disk. 8.0 worked, but as soon as I tried to upgrade it to 8.3, the forcequits began again.
    Desperate, I finally brought my home laptop with 8.5 in, and overwrote the malfunctioning work version of 8.5. I reinstalled the proper license key, and things were WORKING again...for a while.
    Then this selective amnesia started...
    Is my computer possessed?
    Has this happened to any other LW Mac user?
    Any suggestions?
    Be Well.
    Greg
    Mostly solved...
    I opened the Pref files and did some force adding of plugins...After a bit of back-and-forth, I got the keys to come up.
    I then brought in an older Modeller pref and force added the menu entries to the newer one...Opened Modeller and...
    I got my Menus back!
    I'm back & running...just wish I knew WHY my last install of 8.5 just started the force-quitting...
    Greg
