Thread: enormous scene file size
    Using 8.5 on PC I have been working on a scene for several years, a few months ago the rendering and general scene handling deteriorated to the point where I gave up, it was crashing and very slow. Looking at it all again I see that at a certain point the scene file size went from around 700k to 10Mb and then 250Mb, I am no expert but I know something is badly wrong, but I don't know how to look or where to look for the corruption ? Even now I can use the scene at 10Mb in size but I add certain small objects and when saved it is huge again like 250Mb Thanks for any help
    pixinc
    Hastings, New Zealand
    7,731
    You probably have multiple instance of the old spreadsheet in your scene file.
    Go to www.kevman3d.com and download a plugin called lean clean scene machine.
    problem solved
    Great its fixed , thank you so much
    pixinc
    7,731
    I had the same thing happen a couple of years ago on a job.
    Luckily Kevin had just written that plugin. I couldnt even load the scene file
    into a text editor to try and fix it that way. Make sure you dont use the old spreadsheet. or if you do, edit the scene file. I had thousands of instances of that spreadsheet in my scene file.
    Triglycerous Gluteous Dave Jerrard's Avatar
    Apr 2005
    Burbank
    1,061
    Another thing that can cause insane scene bloat is the built-in LightWave expressions. If you load anything from a scene that has expressions, you will also load every expression from that scene as well, even if it's not attached to anything. We've had scenes bloated to over 40 MB of expression data, and these were for objects that weren't even in any of the scenes used. In fact, the expressions were for one show, but they ended up in scenes for a completely different show (and different content directory), because somewhere along the line, a scene was created that used a setup from the other show, and than that scene was used for other scenes, and so-on.
    So, use the tool that Larry pointed to for cleaning up the Scene Editor stuff and make sure that you also frequently use the Clear Unused option in the Graph Editor's Expression menu if you're using those.
    He Who Has A Few Expression Bloated Scenes Kicking Around.
    Last edited by Dave Jerrard; 04-06-2008 at 08:13 PM. Reason: Having your head turned into a coconut is usually fatal.
    - Any typos are the result of a creative, yet rebellious keyboard.
    ASUS KGPE-D16 MB
    2 AMD Opteron 6272 CPUs
    32GB Kingston KVR1333D3D4R9S RAM
    EVGA|01G-P3-1556-KR GTX550Ti video card
