Results 1 to 15 of 16
Thread: How do i get rid of the 2 Gb limit ??
    Dec 2007
    Malta
    126
    I am a Tricaster big fan which i adore. BUT being a Final Cut mac editor, I am finding it difficult to transfer a 'rendered for mac' big file onto a firewire drive which is formated on mac in msdos so as to be accessable on both systems. I did transfer a 34 Gb movie file to my G5 through a network cable but it took ageeeeeeeesssssssssss. I must be missing something. Anybody can point it out to me please.
    It sounds to me like the drive was formatted with the FAT32 file system. If Macs can read a drive formatted as NTFS, then you should re-format the drive on the PC using NTFS.
    Between the eyes and ears there lie the sounds of color and the light of a sigh.
    overcaffinated Mr Maze's Avatar
    Oct 2006
    Prescott, AZ
    366
    You can format drives that are bigger than 2 Gigs to FAT32 using Disk Utility on a Mac - you can't do that on a PC/Windows computer without a special program. I have done it to several portable USB drives (80-150 Gigs, approximately) so that large files can move back and forth across both platforms. Works perfect.
    Quote Originally Posted by Mr Maze
    From what I remember, the file size (not the partition size) limit on Fat32 is 2 Gig
    Partition Size Limit on Fat32 formatting under XP is 32 Gig
    Anything above 32 Gig has to be formatted under Win98 or ME if you need Fat32 ( again if I remember right )
    I think most Macs can read any size NTFS partition, but might not be able to write to it
    Geoff Wilson
    Multimedia Team lead
    Training and Helicopter Support Systems
    Agustawestland
    www.agustawestland.com
    Dec 2007
    Malta
    126
    robewil or Mr Maze
    I think I am lost. Robewil is saying that the cause is being formatted FAT32 while Mr Maze suggests to format it to FAT32. I wish you clarify.
    Quote Originally Posted by TIMECARE
    TIMECARE..
    Easiest option is to format the drive as NTFS under windows XP
    Your Mac should then be able to read files from this drive, but might not be able to write to it..
    The other option is to buy something like MacDrive for the PC that will then let you read and write to Mac formated drives under XP..
    Geoff Wilson
    Agustawestland
    Dec 2007
    Malta
    126
    The other option is to buy something like MacDrive for the PC that will then let you read and write to Mac formated drives under XP..[/QUOTE]
    Thanks Geoff. I am already on site to try the trial version and buy it if it works.
    No Probs.. Glad to help
    Geoff Wilson
    Agustawestland
    Definitely not FAT32! That is why you are having your problem. Format in NTFS.
    Oct 2006
    Prescott, AZ
    366
    Maybe I misunderstood... What I was talking about was the ability for OSX to make a larger partition on a FAT32 drive than Windows. However this does not help since you have a 34GB file. Perhaps I should have re-read before I posted.
    Geoff is right, the best option is to format to Mac OS Extended (Journaled) and use Macdrive on the Windows computer. OSX cannot write to an NTFS volume.
    Dec 2007
    Malta
    126
    thanks all ! its nice to get help and feel at home in a comunity
    CreatvGnius
    Guest
    Wow. I learned a great deal in just the past 2 minutes. The contents of this thread is worthy of being re-written as a concise, F.A.Q. (Frequently Asked Questions) item, and posted to NewTek's site. Don't y'all think?
    Besides that, it would be handy if the company behind MacDrive™ was mentioned, along with a URL linking to the trial download. Anybody?
    -PeterG
    MacDrive can be found at http://www.mediafour.com.
    Chen Pan
    [email protected]
    Mac Drive has been known to cause problems on TriCasters.
    It seems to completely tie up the machine at random, often causing startup problems or glitches in live performance.
    We have not tested it in a year or so, but that was the case at one time.
    Be careful installing it and do some good hard tests before relying on it.
    John Perkins
    Software Engineer
    "No, it's my natural color..."
    Unknown Cavern
    930
    32 gbs across a network will take some time. Look at the math:
    Usual network bandwidth:
    100mbs = 100 mega bits per second. Keep in mind that is BITS!!! there are 8 BITS to 1 BYTE so the speed in MBs is:
    100/8 = 12.5 MBs and that is theoretical Thru put.
    and u had a 32 gb file. So that is 36,000,000,000 / 12,000,000 = 3000 seconds which equals 50 minutes to transfer over the network providing it ran at it's max limit all the way through, but due to memory limits and hard drive write speeds the time grows from there. The upside is it is one big file so it would take less time then 32gbs of small files.
    Current system Specs:
    4gb ddr2 1066
    dual 9600 gt (512mb each) running SLI
    9600 black edition amd
    780a nvidia chipset
    XP Pro or XP Pro 64 or Windows 7
