Results 1 to 9 of 9
Thread: Dognle issue - help please
    i've a 32bit LW, i've installed it on a 64 bit system.
    There's NO way i can make it see the dongle, which is fine on other machines.
    I removed-reinstalled several versions of the driver, i even used cleaners from Safenet to clean system, but still no go.
    When i plug it in, i see it among peripherals but it's not seen by LW.
    Can someone tell me all things i should look at ?
    thanks,
    Paolo
    Hey, I recently upgraded to Vista 64 and had the same problem. I had to download the latest Sentinel drivers from their website, then reboot.
    Login to register.newtek.com, and get a new key for LW 64 bit. Then run the registration utility.
    Reboot again, and it worked fine.
    Blog
    Specs:
    Desktop: Q6600 Quad 2.4 ghz, 8GB, 8800 1Gb, Vista Ultimate x64
    Laptop: Core 2 Duo, 2GB, ATI craptastic video card, XP
    and some funny looking Mac's that I don't know much about.
    Newbie Member sntorres's Avatar
    Feb 2007
    San Antonio
    22
    When you opened LightWave did you get a license error? If you did, and the dongle was detected, you should then see a product lock ID listed in the license error window.
    Your not going to have the same license key for XP 64 as you did for XP 32. You have to register with your new Product Lock ID (AKA: dongle ID).
    NewTek Tech Support
    Pessac
    5,181
    Ciao Paolo,
    Are you sure you installed the 32-bit version of LightWave? Did you try installing the 64-bit version too and seeing if that works? If you have come from a 32-bit version you will need to re-register to get a 64-bit license.key:
    1. Login to the Registration system at http://register.newtek.com;
    2. Go to My Products;
    3. Copy the LightWave v9 serial number from there;
    4. Go back to My Home and register a new LightWave 3D;
    5. Paste the serial number you copied and you will be presented with a page where the licence you already registered is filled in, but there are empty cases for the other two platforms. Make sure you verify that the dongle number is correct for the platform you are registering.
    B
    LightWave 3D Trial Edition
    RollerJesus, thanks gonna try...
    Sntorres - no error, it just starts in discovery mode. but it's enough to know i've to re-register it for 64, i didnt think so.
    BeeVee, absolutely sure, it's a 32 bit one. Problem is that i cant see dongle number anywhere into LW, it's like it cant see it at all, but system does.
    I opened two threads (i apologize), but maybe we can unify them and jump here:
    http://www.newtek.com/forums/showthread.php?t=80991
    thanks all
    Paolo
    Hi all, in case you didnt look at other thread, i posted this, maybe it's useful to know:
    "Ok, it's official, i did a direct test: Remote Desktop prevents Dongle (on remote PC) from working.
    Is this a known limitation or is there something i can do about this ?
    thanks,
    Paolo"
    Technical Account Manager
    May 2006
    Texas
    172
    There's one I'll add to the FAQ right away.
    Yes, Microsoft Remote Desktop will not recognize the dongle when it's on the remote PC because RD will only be looking for the hardware on the end it's being operated from. I believe VNC works the opposite way and does actually work with the dongle plugged in on the client side.
    Dan Parker
    I know stuff about NewTek stuff
    May 2006
    Texas
    172
    OK, here's an FAQ:
    http://www.newtek.com/faq/index.php?...ue&category=67
    It's at the bottom.
    Dan Parker
    To be sure i tried to keep the dongle on client side, but with RD it's a no way.
    So it seems i've to buy VNC, no way to do this free.... ;(
    Paolo
