Thread: Last polygon created index number
    Jan 2004
    Canyon Country, CA
    12
    How can I determine the last polygon index number created after I've run a command sequence like the extrude command?
    For example, if I extrude a 4 point polygon the new geometry creates 5 new polygons. I need to be able to select the last polygon created in order to manipulate it further.
    Kevin
    Code Muppet evenflcw's Avatar
    Stockholm, Sweden
    2,642
    How many polygons you got? PolyNDX coincides with order of creation so the last polygons index is the same as the (global) polycount. Ie, if you had 4 polygons, then beveled 5 out of those, index 5 through 9 are those last 5.
    If you want the ID then just grab it of the last element in the polygons[] array generated from editbegin();
    Jan 2004
    Canyon Country, CA
    12
    Thanks! That got it!
