Thread: Multi Camera Rendering
    Is there a way to create an advanced camera setup so you can render multiple views from multiple cameras in a single image?
    Super Member Cougar12dk's Avatar
    Dec 2003
    Denmark
    1,078
    Blog Entries
    1
    Yes, I remember seeing this in one of the early videos of the new cameras. I've never used it though, but there should be a scene in your scene folder called ACT (Advanced Camera Tools), which has a TV studio setup (or something of that nature), with a big screen showing 3 or 4 different camera's in the scene at once. I really can't help you with anyting more than that.... I'm currently rendering an animation and starting a new instance of Layout would only bog the first one down.
    Anyway, hope that helps.... if not, look in your manual for advanced camera tools (ACT).
    Core i7-3770K 3.5Ghz, @ 4.181GHz
    16GB DDR3 PC3-12800 - 1600Mhz
    Gigabyte GeForce GTX 1060 WindForce OC 6GB GDDR5 PCIe-3.0 x16
    Windows 10 Professional 64bit
    What your talking about is using the CCTV shader. While this is true you can use it for what Im talking about, its not using the advanced camera. Advanced camera works with Fprime and the CCTV shader will not. I want to set up multiple cameras that render to a single image.
    Dec 2003
    Denmark
    1,078
    Blog Entries
    1
    Right Sorry, I've not used it very much. Did one tutorial back when LW9 was in one of the first betas.
    Almost newbier spiroz's Avatar
    Helsingborg, Sweden
    186
    Here's an Fprime-friendly alternative of CCTV
    to get multiple views in a single render.
    The simplest, "isometric" way is using Surface Baking Camera,
    check the "Bake surroundings" setting and then use four polys
    (one for each view) mapped to a UV-map, used by the SB-cam.
    A basic setup is attached.
    Attached Files Attached Files
    pimped sock meister clumsycloudy's Avatar
    Sep 2006
    NL
    323
    pretty clever spirosa!
    "Talk to the puppet cause the hand aint listening''
