Thread: Missing button in display options?
    Unemployed Jester sandman300's Avatar
    Apr 2004
    Phoenix AZ
    1,005
    9.3 seems to be missing a button in the display options. I don't remember the name but it was the button that would auto resize background images to fit an object. Was it moved or did they forget to put it back.
    For Is and Is-not though with Rule and Line
    And UP-AND-DOWN by Logic I define,
    Of all that one should care to fathom, I
    was never deep in anything but--Wine.
    Super Member Roly's Avatar
    Mar 2006
    Florida
    329
    It's there for me. It's called Automatic Size. Are you using 9.3 or 9.3.1?
    I think there was a situation like that on a previous version, but I'm not
    100% sure.
    My specs for now:
    Pentium IV 3.4Ghz, 2GB of RAM
    GeForce GTS 250 512 MB Driver Ver. 260.99Windows XP Pro ( 32 bit ) SP3
    Apr 2004
    Phoenix AZ
    1,005
    That's weird. I looked to see if I had 9.3 or 9.31 and I have 9.2 still. Doh. I must have deja-vued updating my system at work. Cool that its back though. Thanks for the info.
    Don't worry, that happened to me as well!
    I had a model opened and worked on it for a long time. Wanted to put an image in the background and couldn't find the AutoSize button! I was going nuts!... Until I fired up another instance of Modeler, made a cube just for testing, loaded the image and in the backdrop properties there it was as it should!
    So I loaded the true model again and everything worked.
    _____
    /- /|/| 3D Animation and Special Effects
