Thread: How do you turn a bitmap with 16 images into an animated sprite in lightwave?
    Registered User jnddepew's Avatar
    May 2005
    NYC
    509
    how would you go about turning an image like the one attached into an animated sprite which you could use for an explosion in lightwave? thanks.
    Hastings, New Zealand
    7,731
    Chop it up into individual images. Load those as an image sequence and map those onto sprites.
    May 2005
    NYC
    509
    Is there any program that can do that?
    7,731
    Youll probably have to cut out each part and save each out individually. Any paint program should do it.
    Jan 2007
    funder
    166
    try using adobe flash
