Results 1 to 9 of 9
Thread: 007
    007
    This is a really tricky set, so I'm not sure how useful it is, but it was fun anyway.
    Set up your LiveMatte key settings first.
    Turn on the LiveMatte Preview and leave it ON.
    Put your "flames" or whatever on the Effects row.
    Apply the effect to your talent.
    This set has a ton of quirky things you can do with it, but the intended effect is with the LiveMatte preview enabled.
    By keying different colors in the subject and enabling/disabling the matte preview you can get some really cool effects.
    Enjoy
    John Perkins
    Software Engineer
    "No, it's my natural color..."
    NYC
    3,340
    Man how did you do that?
    The black portion of the preview key leaks through a little.
    This has what's on the effects bank showing through just a little.
    How did you invert the matte.........
    Thanks for the set,
    Jose Burgos
    NewTek Certified Trainer
    www.burgosfx.com
    FaceBook
    Twitter @NYTriCaster
    19,777
    Hehehe - I know, but I'll let John leak it in his own way and time ...
    Nice application, John!
    Heh, yeah Steve, I figured you would get it
    It's a huge hack right now, that's why the it has the bleed through, but it's still fun to play with.
    John Perkins
    Software Engineer
    Registered User Cineman's Avatar
    Huntsville, AL
    400
    John,
    Just noted that, if you don't post the NewTek Forums again today, it would be good if you could post 65 times tomorrow. If that doesn't work for you, you could spread it out over some number of days. Just subtract the number of posts tomorrow from 65, and then add one more per day, or seven per week.
    Now, how can I tastefully use enough Smileys to surround this post. Besides, I'll be censored for an inappropriate post on this forum.
    Nes Gurley
    boone nc
    125
    How !
    okay so please explain how it works - its like the old lock key - but i can't re-create this - using vt card not vt pro - everything i try ... can't get the matte to work like that
    NYC
    3,340
    It's built into the LiveSet.
    Jose Burgos
    www.burgosfx.com
    FaceBook
    boone nc
    125
    does this work with vt33 card or only vtpro
    i can't get this to work with vt33 card should it work ???? i can get the set to show but never get the matte o actually work.
    boone nc
    125
    okay-iseethekey-mustbethepreviewboxoptionwhereisthespacebar?illtry again.
