Results 1 to 15 of 23
Thread: Lighting without Light
    May 2006
    France
    4,049
    Nothing revolutionary,
    a basic teapot from Modeler, a NULL as Light reference,
    used with Spot to build a direction for normal in
    Occlusion node in DP_Kit (or directly used as Target
    with Directional option in SG_AmbOcclusion),
    direction is coupled with Spot Smoothed Normal
    to build a basic Lambert Diffuse Model,
    A small Angle of 10° in Occlusion node gives
    nice soft shadows.
    Thanks to Simon Lundberg for scene and first input.
    Denis.
    May 2006
    France
    4,049
    You could use Pom's Ambient Occlusion node too,
    it has not normal input, but DP_Kit has a Replace Spot node
    in Processing tab, to replace positions and normal,
    Denis.
    San Antonio, Texas, USA
    13,055
    Am I reading this right? You are controlling the direction of the ambient occlusion by linking it to a NULLs position?
    UI / UX Designer @ NewTek
    May 2006
    France
    4,049
    ...With the substraction of the Spot world position
    to give a pseudo light direction, this is for replacing
    the normal of Spot to orient the Occlusion cone/hemisphere.
    Denis.
    Dec 2004
    London
    4,502
    Yep, that's right. This is a technique I've been experimenting with when I realized that GI was too slow for an animation we're working on. I will post more information and maybe a tutorial when I've done more work on it.
    Are my spline guides showing?
    May 2006
    France
    4,049
    In fact, amb occlusion is not convincing to fake
    entirely lighting on the teapot, even with SubD mesh.
    Since raytracing hit real polys, self (occluded) shadows
    reveal flat/unsmoothed geometry, when the light direction
    becomes tangential to the polygon,
    that's why a Diffuse Model is important to cover
    the areas of the mesh, which are opposite to the pseudo light.
    Note that a bit higher "Shift" is helping a lot to
    avoid unsmoothed polys.
    Denis.
    Xsi has this feature. Captain, High mes and directional occlusion is a great idea. I just watched some training for xsi that used that technique with great results...
    May 2006
    France
    4,049
    Here, the teapot has med/low res, no SubD,
    without Diffusion Shading you get this:
    Denis.
    To add to that... for an interior you will need to use a distance to gradient to fade from directional to nondirectional for good results...
    \\ is sparkling // Iain's Avatar
    Jun 2006
    Edinburgh
    4,441
    Quote Originally Posted by Captain Obvious
    Can we see any of your results in a production scenario?
    portfolio
    The Liver is evil and must be punished!
    Dec 2004
    London
    4,502
    Quote Originally Posted by Iain
    Not yet, no. Once it's in the public, I will show you whatever I can.
    Dec 2004
    London
    4,502
    Quote Originally Posted by dpont
    Denis.
    What does the Replace Spot node actually do?
    May 2006
    France
    4,049
    Replace Spot node let you replace a few
    Spot input like smoothed normal or world position,
    in case you replace them directly in the input
    of the node, i.e: LW Occlusion node hasn't not
    normal input.
    Replace Spot node must be set after the node
    or node chain you want modify.
    Denis.
    Dec 2004
    London
    4,502
    Ahh, that makes sense.
    May 2006
    France
    4,049
    Edit:...Was too fast with my typos:
    "in case you (can't) replace them directly in the input
    of the node..."
    Denis.
