Page 1 of 4 123 ... LastLast
Results 1 to 15 of 53
Thread: Smokey Give Away!
    17,389
    Smokey Give Away!
    Hmm should I really post this here?
    anyway, hereīs a give away scene from me, nothing spectacular just a smokey emitter and a vortex wind field.
    Maybe some of you might find it useful, tweak it or change smoke to fire or something.
    Enjoy
    Attached Files Attached Files
    Super Member arsad's Avatar
    Paris France
    753
    very kind gesture. Thank you very much!
    Thanks Prometheus.
    Working Monkey StereoMike's Avatar
    Luebeck, Germany
    1,931
    Thanks alot!
    mike
    If you are not paying for it, you’re not the customer; you’re the product being sold.
    many thanks!
    Gianandrea aka LAV aka gigionaz'
    the ever changing collage of our avatars
    my site
    LW is the zen way to 3D
    Thanx for taking the time to put this together and share it! Much Appreciated!
    Malmö, SWEDEN
    7,778
    Thanks alot mate!
    Senior Technical Supervisor
    Cinematics Department
    Massive - A Ubisoft Studio
    AMD Ryzen Threadripper 3990X (64 cores/ 128 threads)
    64GB Ram
    Quadro 620
    Windows 10 Pro x64
    17,389
    you are all welcome, my pleasure.
    perhaps more to come before christmas.
    And Thank you Proton for sharing so much yourself.
    ...basically just added some Motion Blur
    Thank You!
    17,389
    Just noticed that something doesnīt seem right in there, it is set to object line, but I didnīt provide an object for that, or something has changed with the settings, so just change to sphere or something.
    Though in hindsight, not a very good sample, and very old, and I would recommend vdb gas solver in Lightwave or do it in blender, and skip fiddling with the older tech, I could make more interesting particle motion effects though, better suited for particles than a pure smoke effect.
    I think it looks pretty good, being HyperVoxles that is. 
    17,389
    Well..it isnīt even 1/4 of what I can whip up for particles alone, I would say..so I had no problem with sharing that level
    But..I have my priorities on other engines and fluids nowadays so donīt think I will experiment with that for quite a while.
    This sample contains a fairly large particle size and too much density, if I would particle magic it, I would increase particles to several millions and reduce particle size like 80-90% and after that try some blurring methods.
    Krita had some really great ones that could sort of keep the sharpness of the edges of the smoke, but blurring everything in between, but thereīs no batch processing for that unfortunately, and fusions blurring isnīt good enough.
    itīs not just about blurring it to get a decent smoke, but to maintain the sharpness in the edges of all smoke swirls, thatīs also how real smoke is mostly looking, I had a thread over at blender forums about doing cig smoke with fluids, and the trick there is also partly to tweak the shader to have the edges sharp and a bit denser and the rest soft and thin.
    Another part is the main curl that often is appearing in a cigg, that is a bit difficult since such curl vortexes arenīt something that I think the fluids themself generate so well, so itīs often a matter of using other forces with that.
    oh sure, but it would cost some CPU power.
    based on HyperVoxels vs RenderTime, i think this is a decent example.
    Aug 2006
    Eureka, CA
    7,099
    prometheus, your new avatar is scary.
    shrox www.shrox.com
    Heavy Metal Landing
    17,389
    Quote Originally Posted by shrox View Post
    Why?
    Are you trying to tell me thatīs why Iīm still single?
    Some filter effects perhaps that isnīt showing the truth properly, not sure whatīs best though..I leave it in ambiguity.
    Sweet..but Psycho.
