Results 1 to 15 of 18
Thread: FPrime + HD Instance = Frustration! :-(
    Super Member inkpen3d's Avatar
    Jun 2003
    amersham, Buckinghamshire, UK
    776
    I have been using HD Instance from Happy Digital for about a year now in my architectural visualisation work and have also recently purchased FPrime from Worley Labs to speed up my production pipeline. Both are really excellent plugins, which compensate for deficiencies in the core LightWave application, and I would highly recommend them for what they can do individually.
    However, what I find really frustrating is that FPrime does not render object instances generated by HD Instance. I have contacted both Graham Fyffe and Steve Worley regarding this issue (incidentally, they both responded very promptly) and apparently this is because there are limitations in the LW SDK. So here I am with these two amazing plugins in their own right that, if they worked together, would be an amazingly useful killer combination. But instead, I am forced to use either one or the other, which is just crazy!
    I appeal to the authors of these two plugins to get together with NewTek and work out a solution to this impasse. Surely, it would be to everyone’s benefit!
    Does anyone else share these sentiments?
    iemedia solutions:
    Web Site
    YouTube Channel
    Scavengers SciFi novel:
    Amazon UK
    Amazon USA
    I couldnt agree more, and i guess most here.
    Feature-wise, full instancing working universally with LW and Fprime is on the very top of my wishlist. I dont even care if instances are not seen in FP's interactive preview, it would be quite enough if it was just on rendering.
    Paolo
    Yes, but that is just a tip of an iceberg. How about why sasquatch doesn't work with Fprime or Kray, and why 3rd party renderers cannot use screamernet for network rendering or image filters or shaders... and the list goes on....
    Major holes in SDK need to be fixed. I'm sure Newtek knows that... unfortunately no one knows when this things will get adressed, if ever...
    bump!
    markus
    3dworks visual computing
    demo reel on vimeo
    instagram
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,131
    Hopefully the SDK will be updated as they go along and change the code for things, but it's not going to happen over one night. I hope that LW will have native instances soon, then maybe Fprime will support it. We'll see when it happens...
    state of confusion
    6,973
    Maby it's NOT LW?
    All 3 above and also Fiber Factory that I know of, are all post processing plugins.
    Maby if they were made to work in the rendering process earlier, I could get FF to work in mirrors and on the CCTV plugin.
    Skype...lost_in_3d_space
    Sager
    I7-4800 OC'd to 3.3 GHz
    12G 1600mhz mem
    256 gigs raided SSD drive
    Quote Originally Posted by prospector
    Maby it's NOT LW?
    I wish there was a workaround, but unfortunately there isn't... If they could make it work then I'm sure they already would...
    Netherlands
    5,560
    Err... well in this case it's really rather unfair to blame Newtek for this one... It's not as if there would be just a bunch of additions to the Lw SDK that would allow this to happen. HD Instance is a volumetric plugin that uses a post processing engine to calculate its doings. That means that it actually uses the Lw render engine to perform certain operations. It's not a stand alone utility. It would need to be rewritten and integrated in Fprime in order to work right.
    You might be happy to know that Nt has reported to have been working on an instancing solution native to Lightwave for within the lw 9.x version range.
    Los Angeles
    7,156
    Maby it's NOT LW?
    FWIW, if you enable Reflections in the Fiber Filter panel and turn on Ray Trace Reflections in the Render Globals panel, FF4 does show up in mirrors (in LightWave's renderer, not FPrime Render). I haven't been able to get the FF4 reflections to look anywhere near as nice as the source FF fibers though. My guess is that LW is actually rendering the FF4 voxels which are used to cast shadows instead of the FF4 fibers. Probably fine for blurred reflections.
    Fortunately, for me anyway, I haven't actually needed to do this yet. Even so, I'll have to ask Binary Arts about this.
    I haven't tried this with CCTV but I'd be surprised if it worked.
    As for Sasquatch not showing up in FPrime, we always render fur in a separate pass for compositing and processing. As good as Sas looks raw, you can make it look so much better this way.
    DRG
    does FF show in fprime ? if it is a volumetric, it could....
    Paolo
    Los Angeles
    7,156
    Unfortunately, no, but it does show up in VIPER the way Hypervoxels do. Also, when you're using FF4 in surface or 'fur' mode, you can see the fibers represented as a wireframe in the viewport. If you want to, you can even see the voxels used for shadow casting in a viewport. Another nice feature is that you can cast raytraced shadows from FF4 fibers.
    If you'd like to see for yourself, I believe there is a downloadable demo available.
    Since you got me started, here's some more info:
    FF4's styling tools in Modeler are very good. The resulting guides are compatible with either Fiber Filter or Sasquatch.
    Unlike Sasquatch, one thing FF4 doesn't have is built-in dynamics for 'fur' mode. For that, you'll need to create guides and apply ClothFX or some other displacement method.
    Each plug-in clearly has its strengths, and depending on the effect I'm going for, I may sometimes use both FF4 and Sas in my projects.
    DRG
    Fredericton, NB, Canada
    169
    Quote Originally Posted by Exception
    Actually, it wouldn't be too hard. HD Instance only uses LW for querying the textures. Possible solutions are 1) Newtek helps FPrime to work with volumetric plugins, or 2) Worley puts in a volumetric 'hook' into FPrime that I can plug into, or 3) I put a hook in HD Instance that Worley can query from FPrime. Doesn't sound like anything that can't be solved over a couple of beers. There is one potential drawback, which is that both FPrime and HD Instance (and LW) will all be using RAM for their various data structures, but that might not be too bad in most cases.
    - Graham Fyffe
    proprieter, Happy Digital
    Jun 2005
    Reading UK
    3,136
    Sounds like option 2 or 3 would be the best solution. Thing is tho, fprime can already render Hypervoxels, so hopefully you guys could work something out that would indeed benefit all!
    i7 X3930/32GB/Quadro 4000
    Jun 2003
    776
    Quote Originally Posted by fyffe
    This is excellent news Graham - I knew you'd come up with a possible solution
    Like Steve Cullum, options 2 or 3 would be my choice. That way you and Worley do not have to rely on Newtek coming up with future SDK modifications to help FPrime to work with volumetric plugins. On this point it is worth bearing in mind that if Newtek are working on introducing instancing in a point release of LW version 9.x, then there's a possible conflict of interests from their point of view - they might not be too keen to spike their own guns by helping two commercial (and relatively inexpensive) plugins that, when used in combination, would render instances at lightening speed!
    I for one would be more than happy to pay for an upgrade to HD Instance just to have the seamless integration with FPrime.
    Regards
    Peter
    iemedia solutions:
    Web Site
    YouTube Channel
    Amazon UK
    Amazon USA
    Jun 2005
    Reading UK
    3,136
    :agree:
