Results 1 to 2 of 2
Thread: format error with mdd
    Super Member LightFreeze's Avatar
    Sunny Scotland
    911
    I have an object which I`m deforming with bones and when I scan the mdd with ClothFX it generates an mdd file with a `format error` and I can`t use the mdd, however if I deform the same object with a procedural displacement and no bones I can scan the object and get a valid mdd file, what am I doing wrong? I`ve attached 2 scenes, one with bones and one with a procedural deformation, could someone check and see if they get the same?
    I also tried it with a much simpler bone setup and that worked
    Attached Files Attached Files
    VueScripts.com
    __________________
    win32
    core2duo E6500
    GTX 260
    Sunny Scotland
    911
    Think I sussed what I did, I imported an object file and was using that before I saved it as a lwo and although later on I replaced it with the lwo clothFX was still showing the format error. Starting a new scene with the lwo and imported rig seems to have done the trick
    VueScripts.com
    __________________
    win32
    core2duo E6500
    GTX 260
