Thread: Logo Help
    Jun 2007
    Pa.
    100
    Logo Help
    I'm creating this 3d sphear,and trying to surface it like the jpeg photo shown.
    I need to cover the entire sphear as it will be spinning in the logo.
    I posted for help last week,and someone suggested trying to Boolean the sphear which I did (see object) but I don't like the way it looks
    If I can't surface the sphear like the photo,is there a way to take the Booleaned sphear's outer surface polys,and make each segment one flat surface to bevel the edges?. I think if it had an outer bevel,it would look closer to the original.
    Iv'e included the original photo,booleaned sphear
    Thanks ...Bill
    Attached Files Attached Files
    Hastings, New Zealand
    7,731
    You can do the boolean or apply a texture map in that pattern. Does the grid pattern need to be cut into the sphere?
    Jun 2007
    Pa.
    100
    Hi larry, No,I'm trying to get a smooth surface like the original,but I really don't need the fisheye look.
    The boolean sphear looks like a weird basketball to me !!
    7,731
    Try a gradient in the color channel based on light incidence.
    Jun 2007
    Pa.
    100
    I tried a gradint,but couldn't map it on the sphear,can you post some settings? I'm kinda new at this....but learning!
    7,731
    The gradient is not an image map created in a paint program. LW has its own built in gradients that you can access from the texture editor.
