Results 1 to 2 of 2
Thread: White noise in Surface Baking Cam (9.3)
    Steam username: Carm3D Carm3D's Avatar
    Earth
    2,334
    Why is this happening?
    I'm trying to bake the effects of Worley's Acid plugin. It renders fine when I'm not using the surface baking cam.
    Carm
    Carm3D.com
    vimeo.com/carm3d
    "All war is deception." - Sun Tzu
    Earth
    2,334
    Okay I've determined that it's the Acid plugin that is doing that. With Acid turned off, it renders normally.
    Carm
    Carm3D.com
    vimeo.com/carm3d
