Page 4 of 4 FirstFirst ... 234
Results 46 to 54 of 54
Thread: Node Item Motion plugin - slow eval
  1. #46
    What do I know? JBT27's Avatar
    Jan 2004
    Chester, England
    2,250
    Quote Originally Posted by dpont View Post
    I can use Spline Map in node Item Motion node editor,
    without crashes here, but as I said before in this thread,
    it was written for Surfacing use, so when you try a node
    tree with a current surface node in other node editor you
    may have issues, since these node editor are clearly
    described as experimental, you are using them at your
    own risk, solving all cases is an enormous task,
    helping somebody with undetailled report, a pain.
    The author,
    Denis.
    My apologies if I came across as a potential or actual 'pain' - I didn't mean to. I know it's experimental, and I was just, err, experimenting - nothing serious, just trying stuff out
    If I can provide detailed reporting, I will. For now, what I did report is all there is - it crashed easily and consistently.
    Julian.
    LW 2015.3 Win 10 Pro 64bit
    http://www.take27.co.uk
  2. #47
    May 2006
    France
    4,046
    Ok, I'm glad to know this is not serious.
    Denis.
  3. #48
    Jun 2005
    Reading UK
    3,137
    Disabling the preview?
    No..just the set up of the nodes. I'll try cancelling the preview and see if it helps!
    i7 X3930/32GB/Quadro 4000
  4. #49
    May 2006
    France
    4,046
    I don't think so, disabling preview is only for speed,
    crashes are caused by what you are evaluating,
    knowing that you will have immediate update in
    opengl windows, something like selecting a Null
    in a (Surface Map!) node for its own Item Motion
    instance is extremely dangerous, I get some
    success in my test above but it is a miracle...
    There are some other limitations I could not fix.
    Denis.
  5. #50
    A BUG PLANET. duke's Avatar
    Melbourne, Australia
    708
    stevecullum try turning on/off Full Scene Param Evaluation - hit "o", and tick or untick FSPE down the bottom right.
  6. #51
    Jun 2005
    Reading UK
    3,137
    Its already deselected duke, but thanks for the suggestion anyway.
    Edit..not tried it with it on tho!
  7. #52
    May 2006
    France
    4,046
    Quote Originally Posted by duke View Post
    Good point,
    mine was "Lock Motion Key In Time",
    pressing "o" in GE.
    Denis.
  8. #53
    708
    Good point,
    pressing "o" in GE.
    Denis.
    I meant just General LW options, not in the Graph Editor. FSPE can cause trouble in some situations and works in others.
  9. #54
    May 2006
    France
    4,046
    I understood what yo meant, my quote wasn't to deny,
    I replied to previous post about specific stability problems,
    Item Motion like GE make a full evaluation of motion path,
    not only for a NE preview, this causes crashes with
    nodes which need also a frame basis motion path
    evaluation.
    Denis.
