Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 54
Thread: Node Item Motion plugin - slow eval
  1. #31
    Super Member omichon's Avatar
    Bordeaux, FR
    727
    So, I tried to extrapolate from Denis's explanations and here is the result.
    I defined a curve path on a Null object, then applied the motion nodes to a 0.5m radius sphere.
    Actually, it works as long as the Null path stay in the -Z. When it comes to +Z, Pitch rotation freeze.
    If anyone has an idea about this limitation...
    Attached Files Attached Files
    www.oliviermichon.fr | 3D Animation, Motion Graphics and Broadcast Design.
  2. #32
    May 2006
    France
    4,044
    Just some comments, since I retreived my sample
    scene and tested it again (and Lightwave too...)
    "Covered dist" is evaluated in the Null Reference Path
    but at Sphere/Wheel position,
    if you take position for Sphere in Item Motion NE
    it couldn't be updated for calculation so
    for IMNE the Sphere is still at zero and positive
    path is skipped.
    I parented the Sphere to Null, and checked
    "World Coordinate" in Spline Map node, this way
    I got directly the position & heading (and pitch
    if your floor isn't flat),
    and just need the pitch with SplineMap node
    since the covered distance was correctly evaluted
    with its world position in Item Motion NE,
    and I didn't need to divide by PI here,
    I just rescaled by the Wheel radius.
    Hope this help.
    Denis.
  3. #33
    Bordeaux, FR
    727
    Hey Denis, Nice to have you back here
    Thanks for your explanations ! I have to play with all that a little more...
  4. #34
    Hey Denis,
    Please do us all two favors:
    1) Put a paypal link on your site to accept donations from the community. Once there, I will donate immediately;
    2) Could you post the scene of which you speak above in post #33? It helps to figure lots of this out with a visual example.
    Number One is the more important of the two. I don't know what your situation is, and that's not important for this, but opening your arms to the thanks of the community could only be good for you.
  5. #35
    Bordeaux, FR
    727
    Quote Originally Posted by UnCommonGrafx
    Since I asked for the same in post #27, I have to second that
  6. #36
    May 2006
    France
    4,044
    Here is what I got,
    WheelBall.zip
    Denis.
  7. #37
    What do I know? JBT27's Avatar
    Jan 2004
    Chester, England
    2,250
    It's been awhile for this thread, but I'm just looking at this for the first time
    Problem is consistent for me: I create a null, keyframe a path for it over 125 frames. Open Motion panel, add Item Motion NE, then add a Spline Map node to that, no connections at that point, select the null in the ref menu, and Layout crashes, every single time.
    Trying to connect first then see what happens - first use of this for me - is it me?
    Julian.
    LW 2015.3 Win 10 Pro 64bit
    http://www.take27.co.uk
  8. #38
    Jan 2004
    Chester, England
    2,250
    Nope.....connected or not - I can't use SplineMap in this NE - crashes every time.
    Julian.
  9. #39
    May 2006
    France
    4,044
    I can use Spline Map in node Item Motion node editor,
    without crashes here, but as I said before in this thread,
    it was written for Surfacing use, so when you try a node
    tree with a current surface node in other node editor you
    may have issues, since these node editor are clearly
    described as experimental, you are using them at your
    own risk, solving all cases is an enormous task,
    helping somebody with undetailled report, a pain.
    The author,
    Denis.
  10. #40
    Jun 2005
    Reading UK
    3,137
    Its a valiant effort by Denis to bring motion control via Nodes, as I think the future of animation in LW should have a strong nodal tie. However as seen, clearly there needs to be a few (or a lot!) architectural changes to allow this to work properly.
    Roll on the future...
    i7 X3930/32GB/Quadro 4000
  11. #41
    May 2006
    France
    4,044
    Adding X-Z keys to a Null for a floor-motion,
    adding ItemMotion NE, Adding Spline Map node,
    selecting the Null, outputing the "Covered Dist"
    to the Y position,
    Is it working, because this is not my first use?
    Denis.
    Edit:...But totally useless for me!
  12. #42
    Sydney
    8,276
    I've found that motion paths slow down LW quite a lot, even on relatively simple things, but in some cases are needed for interactivity :P A catch 22
  13. #43
    May 2006
    France
    4,044
    Disable the preview it is faster.
    Denis.
  14. #44
    Jun 2005
    Reading UK
    3,137
    I just tried it and got an instant crash when I tried to scrub.
  15. #45
    May 2006
    France
    4,044
    Disabling the preview?
    Denis.
