Thread: Glitch in firewire captures
    Newbie Member vip3dran's Avatar
    Santa Barbara, CA
    89
    Posted this msg a few days ago in the VT General Support forum, thought I'd repost here and see if anyone has an idea about what's going on . . .
    When capturing to DV avi - via firewire, using either DVapp or DecisionMaker, If I capture long clips, 20-30+ minutes in length (either video only, audio only or video+audio) a glitch will show up every couple of minutes. It's not a consistent, predictable amount of time, but only lasts 1 frame. In the video, it will look like a jump cut at times, or will show digital artifacting at others. In the audio, it will show up as a total dropout, or will have a 'buzz' only lasting one frame.
    At first, I thought it was a problem communicating with our JVC BR-DV600U deck, but now it also shows up when capturing from a Sony DV900 camera.
    The exact same clips come in fine (glitch free) if I break the captures down into smaller chunks of say 5-10 minutes
    I've been fighting this problem for quite a while (years), and through several motherboard/cpu setups and several different HD array setups.
    Could the firewire card be the cuplrit??
    Current System:
    T(2) build 3890
    Supermicro P4DCE+, dual 2.4ghz
    Escalade 7850 8ch controller
    6-IBM deskstar 75g striped array
    Generic firewire card - VIA chipset
    This is getting to be a big pain in the A**
    Toaster Oven
    Maryland
    1,145
    If the firewire card is the one thing that has remained the same, then I would try replacing it - especially since they cost so little.
    Portugal
    48
    I notice this myself a kind of glitch every 2 to 3 minutes.
    I don't know if it is the same problem, In my case the glitch happen in spite of been firewire or any else. I think the problem come from the electrical installation, something introduce a static or a noise in the electrical installation and it is notice in the system.
    Try to connect your system to a UPS and see if the glitch persists.
    Donīt forget to ventilate the system well.
    Jose Anselmo
    Santa Barbara, CA
    89
    JFAns,
    From your description, it sounds like a similar problem.
    All of our systems always operate with UPS - never without.
    Ventilation is covered - so many fans on our Toaster (both internal and external) that I have it tied down to keep it earthbound. The CPU's generally run at or a little above body temperature. All drives are individually cooled as well.
    Our glitch generally shows up every 2-3 minutes, but only in firewire captures. Anything else captured as RTV comes in glitch-free.
    Walnut Creek, CA
    8
    glitch
    I'm having the same problem but on my component input. No problem with YC or DV
    Les
