Thread: September 2007 Annual Star Wars Convention
    Registered User Bodger Bowham's Avatar
    Jul 2007
    United Kingdom
    25
    Ok, now that I've got you to look here....
    I am having a problem with what appears to be the lighting in my Lightwave Layout.
    When I render a scene on my computer, everything seems to run smoothly. However, when I render the exact same scene file on another computer in my office, the lighting appears brighter, giving me an over-exposed image.
    I have looked at my light properties and FPrime settings and they are exactly the same on both PCs, as are the surface styles.
    I have noticed this problem with only 2 of my scene files (I produce several a day).
    I get the feeling this may be an FPrime plugin issue rather than a Lightwave one, which I have recently upgraded from 9.0 to 9.2.
    Anyway, I have attached the good render and the over-exposed one so you get an idea what the problem is.
    Can anyone shed some light on this issue?
    Thanks.
Name:	blockRtest render farm.jpg
ID:	48818   Click image for larger version.
Name:	blockRtest my telly.jpg
    Dec 2006
    Philadelphia, PA
    5,738
    Wasn't there a change in the intensity of area lights in one of the versions? not sure if it was from 9 to 9.2... maybe some one else has more info...
    also...
    very very sneaky... I was just here for the SW info... hahahaha
    Jul 2007
    United Kingdom
    25
    There doesn't seem to be a change in light intensity between LW 9.0 and 9.2.
    I know this because I also made a render of this file on a third computer, which did not have the same problem as mine.
