Results 1 to 14 of 14
Thread: Lighting issues in LW 9.2
    Registered User Bodger Bowham's Avatar
    Jul 2007
    United Kingdom
    25
    I am having a problem with what appears to be the lighting in my Lightwave Layout.
    When I render a scene on my computer, everything seems to run smoothly. However, when I render the exact same scene file on another computer in my office, the lighting appears brighter, giving me an over-exposed image.
    I have looked at my light properties and FPrime settings and they are exactly the same on both PCs, as are the surface styles.
    I have noticed this problem with only 2 of my scene files (I produce several a day).
    I get the feeling this may be an FPrime plugin issue rather than a Lightwave one, which I have recently upgraded from 9.0 to 9.2.
    Anyway, I have attached the good render and the over-exposed one so you get an idea what the problem is.
    Can anyone shed some light on this issue?
    Thanks.
Name:	blockRtest my telly.jpg
ID:	48683   Click image for larger version.
Name:	blockRtest render farm.jpg
    Pessac
    5,161
    If you are still using FPrime 2, and you are using area lights it's because area lights changed in LightWave 9.2, and were matched in FPrime 3.
    B
    LightWave 3D Trial Edition
    Grumpy Faux-Waver DogBoy's Avatar
    Central London
    1,549
    By the same token, if the other PC isn't running 9.2 then the Area lights will be blown out due to the same change.
    fauxWaver \foʊ-wāv-er\, n. one who likes LightWave, but shuns car-anologies.
    Jul 2007
    United Kingdom
    25
    Sorry, should have clarified.
    Both PC's are in my office and are both running Lightwave 9.2 and FPrime 3.2
    Registered User Andyjaggy's Avatar
    Sep 2003
    Utah
    4,327
    Is there an Fprime 3.2 update?
    Feb 2004
    GA,SC,NC
    300
    are the PC's EXACTLY the same. Try rendering on PCs that are EXACTLY the same. Then you can really narrow down what's causing the difference. My laptop renders better than my PC. It has more memory, faster processor.
    be a billionaire, share your wealth
    I would contact Worley on that one. They *should* be the same, because the math is the same, and it's more likely the renderer than the layout (LW).
    Confirmed -
    I've had the same problem, even with the old frprime 2.1 and lw 8.5. It only happened to me when i was using area lights. The intensities would differ.
    I loaded up both images and flipped back and forth between them. It looks to me like the camera position has been changed. If so, the lighting may be effected because of the camera shift.
    Ron Mills
    San Antonio, Texas, USA
    13,057
    Don't think it's this, but have you tried trashing your config files and letting LW rebuild them?
    UI / UX Designer @ NewTek
    Jul 2007
    United Kingdom
    25
    The camera has not changed, I must have cropped the images at some point.
    I have tried trashing the config files, with no luck.
    Netherlands
    5,560
    The computer with the bright render... if you cut the area light intensity in half... is the problem fixed?
    I seem to recall if layout opens an old scene, intensities of area lights are automatically doubled. Compare the values, and see if that is actually the case. Then it's not Fprime's fault but somehow one computer does double the intensity, and the other doesn't. Perhaps saving out the scene again from 9.2 will fix it on both?
    Jul 2007
    United Kingdom
    25
    Exception, I have tried halving the area light intensity in the brighter render.
    I have attached thumbnails of the good render unchanged, and the brighter render with the intensity now halved.
    They are not identical but are indeed very similar, so you seem to have the right idea. Do you know why this happens?
    What seems most strange to me is that this has only happened with a handful of my scene files.
Name:	08 08 07 test my telly copy.jpg
ID:	49040   Click image for larger version.
Name:	08 08 07 test farm copy.jpg
    have you tried rendering without F-Prime and changing the lights to something other than area lights? after this are they still showing intensity changes? if not then you know the area lights are messing you up; either re-make them (write down location and rotation) and see if that helps...
    -angel
    Back you robots! Nobody ruins my family vacation but me!
