Page 11 of 56 FirstFirst ... 91011121321 ... LastLast
Results 151 to 165 of 832
Thread: Extra Buffer nodes
  1. #151
    Oh, I see. Yes, Hesham, AA doesn't work in the second DP_NPF instance for Global or Extra Buffers but it works perfectly for conventional buffers. The second-instance trick was a genial idea of Denis Pontonnier to transform conventional buffers while the render is made, instead of applying the transformation when the whole image has been already rendered. We might apply for example, a DOF filter here before that the AA or mBlur have been added to our final color output. If we want to perform other transformations to Global Buffers or Extra Buffers, we can use DP_NIF.
    Gerardo
    P.D. Have to find some time soon to write the next article about this kind of usages
  2. #152
    Bump, any chance of this being compiled for Mac?
  3. #153
    Stuttgart, Germany
    13,613
    Quote Originally Posted by MentalFish View Post
    I've got some catching up to do before christmas, and this is on my list - unfortunately close to the bottom of it though.
    Cheers,
    Mike
  4. #154
    Super Member H_Molla's Avatar
    Cairo, Egypt
    349
    guys,
    Gerardo article on HDRI 3D No.30 regarding the extra buffer nodes is AWESOME..
    you will learn a very professional setup even if you are most LW creative artist..
    good work man....good work...we need more ;-)
  5. #155
    May 2006
    France
    4,054
    Fast Blur and DOF nodes
    Added a Fast Blur node for blurring rendered image.
    Parameter input is evaluated 'per frame'
    (for 'per pixel' evaluation of parameter input use the above Blur node).
    Fast Blur can be used as Pre-Process in Image Node Editor with Image Filter NE.
    Reference: Fast anisotropic gauss filtering.
    J. M. Geusebroek, A. W. M. Smeulders, and J. van de Weijer
    Added a DOF Node for simulating Depth Of Field effect on the rendered image.
    A Color and an optionnal Alpha/Scalar must be input as base image in the node
    and a Depth Buffer input from Render Buffer node is also imperatively needed
    to compute the DOF effect.
    Basic setup,
    A "Med Quality" DOF with an animated focus
    from right eye to left eye,
    Adjust "Diaphragm Sides" and "Diaphragm Rotation" to get 'Bokeh' effect on the
    out of focus of image, zero side means disk shape.
    With "Aspect Ratio", DOF effect can be anamorphic.
    Except the Camera focale and Image size, the main Depth Of Field significant
    parameters are the "Lens F-Stop" and the "Focale (Focus) Distance".
    "Use Camera Lens" allows to get this parameters from the current Camera settings.
    "Focus Reference" is for selecting a (Null) Object, this is more paractical for animating
    the Focus point.
    -DOF node has different "Quality" modes, from "low" with probably some artefacts
    to "very high" also very slow.
    "Blur Size" is a multiplier of the resulted DOF effect.
    -Note that for in a realistic DOF effect, Luminosity or Specularity should be overexposed
    in the input image, use the Scalar Buffers from the Render Buffer node as mask with
    a multiplier for overexposing the appropriate region of the original image.
    Available in the x32 version of DPFilter 9.5 and 9.6,
    http://pagesperso-orange.fr/dpont/pl...DP_Filter.html
    Denis.
  6. #156
    Great! Thank you Denis!
  7. #157
    Murcia, Spain
    3,017
    Hope to see 64bit soon, thanks Denis
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
  8. #158
    WOOOW! this is far better than Digital Confusion and faster than native dof!
    Btw, I've noticed it's better to work in LCS in order to get that nice bokeh effect.
    Thank you very much, Denis!
    Gerardo
    P.D: Thanks for the comments, Hesham
  9. #159
    May 2006
    France
    4,054
    DOF node has been updated.
    "Very High Quality" is a bit faster and the transition between infocus and outfocus regions looks mor smooth.
    Artefacts with the other modes, around infocus pixels near outfocus background pixels are less visible but still present in "Low Quality" mode.
    "Quality" mode was not saved/loaded/copied correctly.
    Available in the x32 version DP Filter 9.5 and 9.6,
    Denis.
  10. #160
    button pusher philippe's Avatar
    West London, UK
    109
    Denis, you're amazing !!!
    Dual Xeon 5345, 24 GB, Quadro FX4800, WIN7
  11. #161
    Ok guys, is there any extra steps you need to do or flags you need to switch, because I am getting absolutely zero effect out of it? I've duplicated Denis' example and... nothing? I am confused. I'm using windows 32 bit.
  12. #162
    Thank you, Denis! Great improvement in speed and quality!
    Tobian, you need to enable Depth buffer in the Buffer Root (DP_PFNE or DP_IFNE).
    Gerardo
  13. #163
    Here's a (very) basic scene (I did try a more complex set-up initially). I have the node filter set up the same as Dennis shows.. Only the render comes out without ANY DOF
    Just for contrast - I have the DOF preview enabled, with the same settings inside LW (and LW render looks pretty much identical to the preview, so it's not some logical error?) But the pixel image filter does nothing (and I tried it on the pixel filter version and got a blank render )
    Do I need to enable the depth buffer in some way or is there some switch I needed to activate to make it work?
    I also noticed the fast-blur node also doesn't seem to do anything in the image filter node editor? Could it be related?
    I have downloaded the very latest version (and an older one wouldn't show the DPDOF node!) Checked I don't have any old DP nodes in my plugin folder, and made sure I had the version for V 9.6, which I have installed...
    Hopefully I am just missing something obvious
  14. #164
    Ahhh ok that seems to have resolved it Gerardo It's now being very slow though haha.. gonna do experiments!
  15. #165
    yea, do your experiments, so that you can verify that DP_DOF is faster than waiting a smooth result with AS only
    Gerardo
    AS = Adaptive Sampling
