Thread: Relief maps plugins
    Member Clockmaster's Avatar
    Feb 2007
    Rome, Italy
    230
    Relief maps plugins
    Hi!
    I have just read some documents about relief mapping, relief impostors and so on. This tecnique seems absolutely amazing, since it can also simulate overlapping surfaces without additional geometry!
    There is some plugin that allows the implementation of this advanced shader on Lightwave? It would be wonderful.
    I read about a plugin on an old Spinquad post, but in the indicated site the plugin seems to be no longer present, or at least I can't find it.
    http://www.spinquad.com/forums/showthread.php?t=10683
    http://home.att.ne.jp/omega/tabo/3dlabo/zakki.html
    If someone knows about it, please let me know!
    Bye Bye
    i hope denis makes this one a material node, it 's an excellent candidate to convert to a material node.
    www.bytehawk.net
    1 : Imac 27’ I7 mid 2017 8Gb ram
    Feb 2007
    Rome, Italy
    230
    Thank You very much, and many thanks to Mr. Pontonnier for this very useful addon.
    I guess if this plugin can handle also non height-field structures, like overlapping surfaces, that are explained by Fabio Policarpo in
    http://fabio.policarpo.nom.br/relief/index.htm
    at "Multi-Layer Relief Mapping" section (Multilayer_ReliefMapping_I3D2006.pdf).
    Cheers
