Results 1 to 9 of 9
Thread: Dialectric node problem
    Newbie Member claudioarchi's Avatar
    montreal
    40
    Hi guys,
    I just render this scene with fprime 3.01 i was testing the dialectric node. And it gives me a nice result, but even if double sided material is on, i still don't see the inside of the glasses. Also the refraction look strange. Does anybody know what the problem is?
    Thank you
    Attached Files Attached Files
    How Old? Really? Aww Heck colkai's Avatar
    Staffordshire
    7,809
    first things first, check your raytrace options in the render globals and also check the recursion limit is at least 8. does seem like something is missing.
    Too old to die young.
    montreal
    40
    Thanks Colkai, the raytrace options are on as well as refraction, but recursion limit is at 4. i'll change it to 8. I also model a third glass with a double skin to see what happen. I'll see if i can post somethig o got to get back to work dull!!!!!
    Staffordshire
    7,809
    oh jeez, tell me about it, all day online to thicko clients who realyl should not be allowed near a computer.
    montreal
    40
    Ok i've got the double sided object, i just modeled a solid glass, solve the problem for the reflections. BUT NO SHADOWS....what the hek?!!!!!, i'm using an area light, if i change it for a spot or point light, the glasses will cast shadows....hmmm!!!!
    Two questions, Do you have the dielectric plugged into mixer with a standard air surface and Polyside info switch? and do you have raytrace shadows on?
    Dug
    montreal
    40
    Yes to both questions dog her is the node tree...
    I am Jack's cold sweat Karmacop's Avatar
    Bathurst, NSW, Australia
    2,117
    How big is your area light? Maybe it's to big to cause visible shadows?
    montreal
    40
    karmacop you were so right!!!! it was too big. thank you all for your help
    see ya
